Poorf reception of fuzzy display
Output on TV is fuzzy or unclear.
TV is not on the proper channel
There is a switch on the back of the computer that says channel 3 on the right and channel 4 on the left. Set the TV to the channel that the computer is set to. If it still is unclear, flip the switch on the computer and change the TV channel to the correct one.
Antenna is not connected
If you are certain you are on the correct channel check the antenna and make sure they are connected securely and properly. Wiggle it around to find the position that gives best reception.
You television set needs adjustment
Check the contrast, brightness and other controls on your TV. If any one of these controls is turned to one extreme or the other, there will be no visual display. Adjust them to get the best visual possible.
Mixed computer and TV reception
Your screen switches from TV to your computer.
The TV is set on an incorrect channel
Check the antenna to see which channel the computer should be set on. Either 3 or 4 and make sure the TV is on that channel. See "TV is not on Proper Channel."
Computer won't turn on
You keep pressing the power button and nothing happens.
No power to the computer
Make sure the computer is plugged into the outlet. If that doesn't work, take off the case and check the power cord connection. If the cord is frayed, see the "Power Cord Installation Guide" to replace the cord.
Your television needs adjustment
Sometimes the TV settings are not correct do it might seem like the computer won't turn on. See previous "poor reception or fuzzy display" to fix this problem.
Incorrect power sequence
Make sure all of the accessories (TV, tape deck, and floppy drive)are turned on before trying to turn on your computer.
Cassette program won't load
You keep trying to put it in but the computer doesn't respond.
Cassette volume is too low or too high
If the volume on the cassete is too high, sometimes the tape will not load or it will not give any audio feedback. Check recorder's volume control and adjust it so the volume is at a reasonable level.
Tape is broken
Remove the tape and try loading a duplicate copy of the tape if you have one.
0 opmerkingen
