Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Camera will not turn on
No matter what you do, you can't get your Coolpix to turn on.
Hold switch is turned on
Before delving inside your Coolpix, make sure you've tried turning the camera on by holding down the hold switch. The hold switch is located on top of the Coolpix next to the shutter button.
Drained/bad battery
If your Coolpix won't turn on, you may simply have a drained battery. Try charging the camera for a few hours before turning it on again.
Bad display
It is possible that it appears nothing is happening because the display is bad. If the Coolpix is turned on and the battery is fully charged, but your camera will not turn on it is possible the display is bad and must be replaced.
Bad logic board
If your Coolpix still does not work after attempting the above solutions, the problem most likely lies in the logic board of the camera.
USB Port Does Not Cooperate With Computer
When my camera is plugged into my computer, the computer does not recognize the camera
Remove memory card and insert it into computer
Putting the memory card directly into the computer bypasses any problems that may exist between the camera/computer connection.
Unplug and Plug Back In
The cable may have formed a bad connection or it could not have been physically plugged in properly. Plug the cable back in carefully to ensure a good connection.
Camera cord could be malfunctioning
If the cord is broken, then the problem lies with faulty wiring within. You may need to purchase a new cord.
May need specific camera software
Access to data on the camera may require the connected computer to have certain software downloaded in order to communicate with your camera. Downloading this could potentially be important for getting desired data off your camera. Check the official Nikon website to find out more about the most recent Coolpix software.
Coolpix lens will not open
No matter what you do, you can't get your Coolpix lens to open.
Remove batteries, clean battery port and replace with fresh batteries
Remove the batteries and check if there is corrosion in the battery port. Replacing them with new batteries to make sure that the camera has enough power it needs to start up properly.
Sand or dust particles lodged in them
If there is a foreign particle lodged in the lens mechanism it will prevent it from opening properly. It is important to be careful with any attempt to clean the lens device, but compressed dust remover is often an easy and effective way of doing this.
Coolpix will not connect to Wifi
No matter what you do, you can't get your Coolpix to connect to Wifi.
Poor Wifi Signal
Before attempting to decrypt the Coolpix physically, simply try to relocate to a more prime position towards the Wifi router that is producing the given signal.
Correct Source of Wifi
If your Coolpix won't connect to Wifi through an Iphone, Ipad, Android Smart Phone, or Android tablet, make sure that the 'WMAU' (Wireless mobile Adapter Utility) has been installed onto the given device. Download the app on the given device via Apple Store or the Google Play Store.
2 opmerkingen
Nice summary. But when my camera was plugged into my computer, the computer did not recognize the camera because I used the wrong port just below the right connection( they look the same. Poor camera design). Battery before this was fully charged. Did I FRY the camera because of this? Guide book does not explain this situation. . . What are my options? Thanks
antek24 - Antwoord
Hey i’ve had this camera for about 4 years and i thought i broke it so i just left it but one day i realized that i had the charger and i started charging it i left it for 3 hours after 3 year that i left it be dead so then it started charging but now it will charge for a few seconds and then the light will stop flashing. But my camera is a Nixon coolpix S5200 but a few years ago i broke the second portal the lowest one but idk if its the charger or something else when the light is flashing its the first portal but then fail thank you
Evanny Castillo - Antwoord
