Lens Error Problem
When the camera turns on the LCD indicates a lens error
Connect to power source
Replacing the battery or connecting to another power source such as an AC adapter or a USB cable can solve the problem. Make sure the memory card is out of the camera when you attempt to power up the device.
Hold shutter button down while powering on
One possible quick solution to this problem is holding the shutter button down and facing the lens upward while the camera is powering on.
Place camera lens down and power on
Placing the camera lens down and powering on can sometimes realign the pins in the lens extender if the are misaligned.
Gently tapping camera
A gentle tap on the side of the camera with the lens can possibly realign the pins.
Gently pushing or pulling on the lens cover can have the same effect.
Camera Will Not Turn On
The camera will not turn on when the power button is held
Drained batteries
First replace the battery in the camera with a fully charged replacement. If the camera still does not turn on try holding the power button.
Remove memory card
Try removing the memory card from the camera and then powering it on with charged batteries.
Bad display
It is possible that it appears nothing is happening because the LCD display is bad and must be replaced.
Bad logic board
If nothing else seems to work the problem most likely lies in the logic board.
Camera Does not Focus
When trying to take pictures, the camera does not focus.
The Lens could be defective
If the lens is defective, replacing the lens is the only option.
The camera does not take photos
The camera cannot take any pictures when the shutter-release button is pushed.
Battery Problems
The problem may be linked to an empty or defective battery. To fix this, try replacing the battery.
The flash does not function
When trying to take pictures, the flash does not go off.
Drained battery
A low or poorly functioning battery may be the problem. Replace the battery.
Flash assembly may be malfunctioning
Replace the flash assembly.
Casing is damaged
The camera has undergone external harm. Replace the exterior casing.
LCD screen won't display anything
The camera's LCD monitor doesn't show anything when it is turned on.
The camera might be in sleep mode
If the camera is in sleep mode, slightly pressing the shutter-release button will turn on the display again.
Battery Problems
The USB connection cable is connected
If the USB cable is connected to the computer, the display will turn off on the camera. Unplug the USB cable to reestablish display.
The monitor has been damaged
If the monitor is damaged or broken, you will need to replace the LCD monitor.
Één opmerking
a red light is on the screen when the power button is pressed, on auto settings. What could it be?
edermau - Antwoord
