Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Laptop won’t turn on
There is no response when the power button is pressed
Faulty Power Adapter
Plug the adapter in and check to see if the charging light comes on. If it does not, your power adapter may be faulty and need replacement
Faulty Battery
If the laptop only works when plugged in regardless of charge time your battery may need to be replaced. Check that the adapter is working first.
Camera won’t work
The webcam is not working
Faulty Driver
The driver for the camera may be out of date or faulty. Open the Start menu and go to Settings>Devices>Printers & scanners. Scroll to the bottom and click “Device Manager”. Look under “Imaging devices” for your camera. Right-click it and select “Update Driver Software”.
The Camera is disabled
Go to same menu as seen under “Faulty Driver” and select “Enable” instead of ‘Update Driver Software’.
Built in microphone is not working
The microphone is not registering any sound
Microphone Disabled
The microphone may be disabled. Go to “Recording Devices” by right clicking on the speaker icon on the right side of the task bar. If the icon is not on the taskbar click on the arrow/carrot and it should be in the pop-up menu. Look at the listed microphones. If no microphones are listed or just the built-in microphone is missing, right click in the window and ensure “Show Disabled Devices” is checked. Locate the device, right click and select “Enable”.
Microphone Volume is not up
Follow the instructions under “Microphone Disabled”. Once you identify the microphone check to see if the green bar beside it moves as you make sounds. This shows that the microphone is registering sound. Right click on the microphone and go to “Properties”, to the “Levels” tab and adjust the volume. If you have headphones, it may be useful to check the “Listen to this device” box in the “Listen” tab before adjusting the volume.
Computer Overheats
While you are working the body becomes very hot and may lag or shutdown
Clogged/Dirty vents
Air may not be circulating well due to dust or debris in the vents or fan. Open the case and use compressed air to blow dust out of the vents and fan.
Inadequate Amount of Thermal Paste
Your computer may not have adequate contact between the heat sink and processor. This is usually caused by a lack of thermal paste or by air in between the two components. To fix this, completely clean off any old thermal paste, then apply a bead of new thermal paste directly in the center of the processor. Gently push the heat sink back in place and tighten screws to lock down the heat sink.
Display turns white
When the Laptop is turned on the monitor is white or displays nothing
Attempt a power drain
Turn the laptop off, and remove the power adapter and battery. This will drain excess charge from the laptop which may have stopped the display from working. After waiting for 2 minutes replace the battery and power adapter and turn on the Laptop.
2 opmerkingen
My Lenovo laptop flex 4 won't show anything on screen. But it turns on. This started by shutting down when I try to move the laptop. Can you help me with this
Godfrey - Antwoord
emails sent from my Lenovo appear on recipients devise as script
Karen Wright - Antwoord
