Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Screen does not illuminate or turn on
When the computer is turned on, power indicators are on but the screen does not illuminate.
Screen brightness is too low
Windows can automatically lower the screen brightness depending on multiple conditions, including battery level and usage. To ensure that the brightness level is not too low, repeatedly press the Fn and F12 keys to increase the display brightness.
Device needs to be restarted
Remove all cables connected to the laptop (power adapter, HDMI, mouse, keyboard, etc). Make sure the device is powered off. Press and hold the power button for 60 seconds to restart your laptop. When done, attach the power adapter and let the laptop charge for a couple of minutes. Afterwards, power on the device as normal. If there are no indications of power either from the power button, port lights, or noise from the laptop fan, then you should move to the "Laptop does not turn on" section of this troubleshooting guide.
Display mode needs to be reset
Press the Windows key, Ctrl, Shift, and B at the same time and release. This keyboard shortcut refreshes the display connection on the laptop.
Peripherals are interfering with the display signal
Peripherals are devices (wired or wireless) that are connected to your computer, such as a keyboard or a mouse. Disconnect all of these devices from your laptop. If a peripheral's software or driver is corrupted, your display could operate incorrectly.
Test the display with an external monitor
To test the laptop's display and cables, connect the laptop to an external monitor or TV with an HDMI cable. Afterwards, restart your computer. When the laptop reboots, it should find the external display and start using it to display the desktop. If it does not display automatically, press the Fn and F10 keys at the same time. This should switch your systems display onto the external monitor.
Note: If your screen does successfully display on the external display, then you will need to look into replacing the LCD cables or even the LCD screen.
Graphics driver needs to be updated
If your graphic's driver is corrupted or out of date, the monitor could fail to function. On an external display, navigate to Lenovo support to download and install the latest graphics driver.
Windows need to be updated
Windows controls much of the built-in systems on the laptop. As a result, an outdated version of Windows can create issues with the display. Using an external display, navigate to the system settings and search for "Software Update" and install if one is available.
Explorer process needs to be restarted
The explorer.exe
executable file manages several essential processes on the laptop. Issues with this file could lead to the display not functioning properly. Try restarting the process with the following steps on an external display.
- Press the keys Ctrl, Shift, and Escape at the same time to open the Task Manager.
- Click "Details."
- Locate and select
explorer.exe
and click "End Task." - Restart the laptop to see if the display functions properly.
Laptop needs to be factory reset
This is a last resort option as factory resetting will lose all data on the device if it is not backed up. If possible, use an external monitor and back up the data on the device before continuing. To factory reset, open "Settings" and search for "Factory Reset."
Contact Lenovo support
If the above troubleshooting steps do not solve the device's issue, contact Lenovo support. They might be able to provide more specific troubleshooting instructions as well as advanced resources.
When the power button is pressed, the device does not respond.
Battery level is too low
Attempt to plug the device into a power adapter. As the battery could be completely dead, it may be necessary to wait for a few minutes for it to charge to the minimum level for use. Make sure the wall adapter is providing power before plugging in the charger. Test this by trying to charge your phone or any other device which you can tell if power is coming from the outlet.
Faulty power adapter
If the laptop continues to not respond, ensure that the power cable is securely plugged into the computer. Try another outlet, and if possible, another power cable. The laptop also has a charging indicator light; if the computer is receiving power, this light will illuminate.
Device needs to be reset
If the laptop continues to fail to power on with a working adapter, attempt to reset the device by using the pin hole reset button on the left side of the laptop, between the SD card reader and the headphone port. Alternatively, disconnect the battery from the motherboard using this guide and let the device sit for a few minutes. Afterwards, reconnect the battery and try to power on the device.
Laptop is stuck sleeping
If the device still does not turn on after a power drain, the laptop may be stuck asleep or hibernating. Alternatively, it is possible that the device experienced a software issue. In some cases, it may be necessary to hard reset the laptop. Press and hold the power button for 30 seconds. Afterwards, press the power button to start the laptop again.
The screen is too dim
If hard resetting the laptop does not work, the display may be too low to a point where it appears to be off. Make sure to plug the device into power as the screen may dim when on battery power. Hold the Fn key and repeatedly press the F12 key to increase the screen's brightness. To learn more about the function key shortcuts, refer to the Lenovo user guide.
Windows update corrupted the laptop
If the device no longer turns on after running window updates, attempt to boot Windows into safe mode. To do this, refer to Microsoft's guide to Start your PC in safe mode with Windows from a black or blank screen.
Battery does not hold a charge
The battery does not fully charge, does not last long on battery power, or does not charge when plugged into the power adapter.
Incorrect battery settings
Ensure that the battery settings are configured correctly in the Windows settings. You can access the settings by searching for "Power & Sleep Settings" in the Start menu. Check that the "Battery Saver" option is off and that the "Battery Percentage" is set to display.
Screen brightness is too high or demanding usage
The battery life of a laptop depends on factors such as usage habits, running applications, and display brightness. If you are using power-intensive applications or running your laptop on high display brightness, this can significantly reduce the battery life. Adjusting your usage habits can help prolong the battery life of your laptop.
Run a power troubleshooter
You can run the Windows power troubleshooter to detect and fix any issues with the battery. To do this, search for "Troubleshoot" in the Start menu and click on "Power." Follow the on-screen instructions to complete the troubleshooter.
Uncalibrated battery
Calibration involves fully charging and discharging the battery to help it regain its full capacity. You can do this by fully charging the battery, unplugging the charger, and allowing the laptop to run on battery power until it turns off due to low battery.
Outdated BIOS and drivers
It is possible that outdated BIOS or driver software is causing the battery issue. Check the Lenovo support website for any additional updates for your laptop.
Steps to check for support:
- Go to the Lenovo Support Website. Download the updated versions of the BIOS, Energy Management, and OneKey Optimizer software for your device.
- Check the battery status in Energy Management or OneKey Optimizer.
- If the battery status is "Good," shut down your laptop and connect the AC adapter for 5-6 hours to allow the device to fully charge.
- If the battery status is "Exhausted/Damaged," run the battery gauge reset in Energy Management and OneKey Optimizer. Check the battery status again once complete.
Battery needs replacement
If the battery is old or damaged, it may need to be replaced. Lenovo sells replacement batteries for their laptops or you can search for third-party replacement options. To replace the battery, follow the guide here.
If none of the above steps work, it is possible that there is a hardware issue with the laptop. Contact Lenovo support for assistance as they can provide further troubleshooting and repair options.
The laptop does not output any sound
No sound plays from the laptop's speakers, any attached headphones, or may be very faint and hard to hear.
Laptop is muted
Occasionally, Windows can mute the system’s volume when headphones or other devices are unplugged from the computer. To check that your computer is not muted and change the volume, click on the sound-icon in the taskbar. Change the volume as needed. If the computer is muted, changing the volume will unmute the computer.
Incorrect audio output device
It is possible that Windows is outputting audio to a different device than expected. Check which device it is using by clicking on the speaker icon on your taskbar, expand the window with the up arrow button, and ensure that your speakers or headphones are being used. Trying each audio device may be required if the names are not familiar.
Individual programs are muted
Right click the sound-icon in the taskbar and click “Open Volume Mixer.” Each column represents a currently running program. Ensure that the program you are not playing sound from is muted. Additionally, check that the main output volume (usually the first in the list) is unmuted as well.
Outdated audio drivers
It is possible that the drivers for your audio devices need to be updated. Search for and open “Device Manager.” Expand the section titled “Sound, video, and game controllers” and right click on the sound device you are using. Select “Update driver software” and follow the onscreen prompts. After you are finished, restart your computer.
Symptoms started after a driver update
Windows may have updated the audio device drivers on your behalf which can cause issues to arise. To solve this, you can roll back your audio drivers to an older version. Search for and open “Device Manager.” Expand the section titled “Sound, video, and game controllers” and right click on the sound device you are using and select “Properties”. Select the “Driver” tab. If there is an older driver available, the “Roll Back Driver” button will be available. Click the button, follow any prompts on screen, and restart your computer.
Audio service stopped
The audio service on your computer may have stopped running or encountered an issue causing it to fail. To restart the service, right click on the Windows icon on the taskbar and select “Run.” Type services.msc
into the box and click “OK.” Scroll down to “Windows Audio” and double-click to open. Check the service status. If it says stopped, click “Start” to resume it. Additionally, ensure that “Startup Type” is set to “Automatic” to ensure that it begins when your computer turns on.
If none of the above steps have solved the issue, it is possible there is a hardware issue with the laptop. Contact Lenovo support for assistance through the Lenovo website as they can provide specific troubleshooting options as well as professional assistance.
Webcam shows black screen or no video
The webcam cannot be detected, displays a poor quality video, or no video.
Camera privacy slider is covered
On the top of the monitor case, there is a ridged portion of plastic that can be slid left and right. If there is a red dot in the camera, slide the plastic left until the red dot is completely removed from the camera.
Other applications are using the camera
If the camera indicator light is on, it is possible that another application is using the camera. Close all other applications (except the application that you currently want to use for the webcam).
Protective seal is covering the camera
If the webcam is displaying a blurry video, it is possible that the protective seal is still covering the camera. If the protective seal is still on the webcam, remove the protective seal.
Room lighting is too dark
If the video appears grainy, there may not be enough light in the room to see the video. Adjust the lighting in the room to allow the webcam to capture a clearer video in a brighter room.
Computer needs to be rebooted
Attempt to reboot the computer by powering off and then powering on the machine. Check to see if the issues with the webcam are still occurring.
Antivirus settings are blocking the camera
It is possible for some software to disable the webcam for security reasons, such as an antivirus. Check any antivirus software settings and preferences that may be causing the camera to be inaccessible or not enabled.
Camera does not appear on the device list
One possible fix is to enable the camera with Lenovo Vantage.
- Open the Lenovo Vantage software.
- Go to Quick settings and check if the Camera option is Enabled. I
- f it is not enabled, then click Enable.
Another possible fix is to enable camera in device manager.
- Press the Windows + R keys and enter the command
devmgmt.msc
. Click OK, which will open the Device Manager. - Go to the cameras subgroup. Select the camera below and right click.
- Check if there is an enable device option. If there is, click to activate the camera.
Privacy settings are blocking access to camera
Navigate to Settings > Privacy and Security > Camera. Then enable Camera Access. You might also have an option to specify specific apps that can access the camera.
Keyboard shortcuts need to enable the camera
Find a function key that has a camera icon on it (usually this is the F8 key). Simultaneously press Fn + F8 (or the corresponding function key with the camera icon), or just press F8 (or the camera icon function key) on its own. Check to see if the camera is functioning properly after clicking these keys.
If none of the above steps work, it is possible that there is a hardware issue with the laptop. Contact Lenovo support for assistance, as they can provide further troubleshooting and repair options.
0 opmerkingen
