Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Computer Won’t Turn on
The laptop will not turn on or show any signs of powering on
Faulty Power Cord
Ensure the power cord is plugged in and charging icon in the top left of screen appear. If the power cord is plugged in and the charging icon fails to appear. The power cord is faulty and should be replaced. Try replacing it with this Battery replacement guide
Faulty Battery
Ensure the power cord is plugged in and charging icon in the top left of screen appear. If the laptop only turns on when the power cord is plugged into the laptop. The battery is faulty and should be replaced.
KeyBoard or Keys not Responding
The keys don’t respond or are missing or broken
Faulty Keyboard
If none of the keys are working then the keyboard is faulty and needs to be replaced. Try replacing it with this Keyboard replacement guide
Keys Stuck in place
When the keys can’t be pressed there may be something under the key. Find something to pry up the key. A kitchen knife should work. Then wipeout anything that is underneath.Then snap the key back into place.
Keys are missing
If a key is missing consider buying a new one and snapping it into place on the keyboard.
Speakers are not working
No sound will come out of the laptop
Volume is turned down
Make sure your volume is not all the way turn off by clicking the speaker icon in the bottom right. If there is no sound coming from the speakers then connect headphones and see if they produce sound. If the headphones work your speakers may be damaged and need replacing. Try replacing it with this speaker replacement guide
Computer running slow
Programs loading slowly
Hard Drive full
Your hard Drive might be full and need of a replacement. Replacing it will wipe all your current saved data and allow you to start with a clean slate. Try replacing it with this hard drive replacement guide
Not enough storage
Another option is to obtain a external hard drive and move some of your files form your computer to the external hard drive.
LCD display not working
Screen partially/completely blacked out
Screen back light not on
If your device is on and your screen is still black, your backlight may not be bright enough. In order to turn on your backlight brightness up, press the F12 key until the screen becomes visible. If after pressing the F12 key, your screen still doesn’t light it, you may need to replace your screen. Try replacing it with this LSC replacement guide
Screen shattered
If your screen is partially or completely blacked out, or has an LCD bleed, you will need to replace the entire LCD screen. You can determine if it is an LCD bleed by analyzing the screen to see if there is any light coming through or “bleeding” through the black background. Try replacing it with this LCD replacement guide
3 opmerkingen
why my coverage bar not available and my processor data and ram data on pc info are not available?
Faiz Nhakim - Antwoord
Lenovo G40 on not displaying after even changing ram what is the problem
Onazi Gabriel - Antwoord
Lenovo G40 is not displaying even after changing ram
