Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Computer Fails to Power On
Your HP Envy x360 m6-aq105dx will not turn on.
Battery’s age
The age of the battery affects how well a computer operates. If the battery is older than the manufacturer has stated, then it might not be able to hold the designed amount of power. In this case, the computer won’t be able to turn on.
Battery not plugged in
If the battery isn’t completely plugged into the laptop, then it won’t be able to turn on.
Device will not hold a charge
Some components in the battery itself might be broken, so in this case, the battery may need to be completely replaced. It is recommended to buy a battery from HP themselves to prevent any issues that might occur from buying from a different supplier.
To help you fix the battery:HP Envy x360 m6-aq105dx Battery Replacement
The computer is becoming warm and just shut off
Fan is making a loud noise
In most cases, overheating is caused by a buildup of dust on the fans, making them work harder to decrease the temperature of the laptop. If the fans are blocked, the laptop is not able to be properly ventilated. Thus causing overheating and could lead to the computer shutting off.
The computer becomes really warm and shuts off
Overheating can be reduced by going into the computer’s performance settings and changing the graphics, brightness, or resolution. Performance can also be increased by closing an excess of applications. A hardware issue could be decreasing performance, so in that case, diagnostics can be used to find if there are any hardware issues. In this scenario, turn off your laptop, leave your laptop alone for about 5 minutes, turn it back on, and about once every second press F2 until diagnostics open. Once diagnostics is open, chose System Logs -> Thermal Events, then you can see if there were any spikes in temperature, and when. You can also select Performance -> Intel SpeedStep, and make sure Intel SpeedStep is enabled.
The touch pad stopped responding to any of my actions
Computer devices is outdated
Your drivers may be outdated. To update them, visit the following website: https://support.hp.com/in-en/drivers/lap.... Choose either to enter the serial number or let HP detect your laptop. HP Support Solutions program will be installed on your laptop. Run the program and follow the steps provided.
Touch pad is unresponsive
There may be a hardware issue with the device, in this case, a hardware test will need to be done. To run a hardware test, first turn off the computer. Next, turn on the laptop using the power button, immediately press the F2 key repeatedly about once every second until the Hardware Diagnostics menu is present. *Select the touchpad/mouse and run test. Initiate a system refresh by going to the following website and follow instructions to Refresh PC without affecting files: https://support.microsoft.com/en-us/help...
Computer stopped working and froze up
Your HP Envy x360 m6-aq105dx is slow or frozen.
Computer is unresponsive
In some cases, you can restart your computer and fix the issue. However, in most situations, this is a temporary solution.
Computer is still unresponsive
If there are too many applications running in the background of your computer, it can cause the computer to slow down. In this case, close applications when they’re not in use. You can also go to Task Manager and close any background applications. To open Task Manager hold Ctrl, Alt, Delete keys at the same time. A blue screen should appear, click Task Manager, only click only on the tasks you know. Click the task you want to close, then click the End Task button in the bottom right corner. You can also go into your computer’s performance setting and change the graphics or resolution. Also, if there’s an excess of things plugged into the computer, performance can be affected and slow down or freeze the computer.
To much on the disc
Another option to speed up your computer would be to clean your computer’s disc. This can easily be done by going online and using the link below to clean computer discs.
If you want to clean your disc then go to :https://www.ccleaner.com/
The computer will not connect to the internet
Computer wireless devices are out of date
The most common problem that causes issues with network or wireless connections is an outdated wireless adapter drive. Before buying a wireless adapter drive, run a network troubleshooter on your computer. https://www.ccleaner.com/
0 opmerkingen
