Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Garmin Nuvi 1390LMT will not turn on
You have tried turning on your GPS and nothing is happening.
Drained battery
If your GPS does not turn on, the battery may be very low on charge. Plug your GPS into the charger, wait 5 minutes, and try turning on the GPS. If that does not work, wait until the GPS is fully charged, then try again.
Dead battery
If charging the battery does not do anything, the battery may be completely dead and not able to hold a charge. In this case you will need to replace the battery. See the Battery Replacement Guide for help.
Battery connection/no battery
The battery may not be connected to the GPS correctly. Open the unit, ensure there is a battery there, remove it, and put it back in. Try turning the GPS on again.
Motherboard
If replacing the battery still does not work, there is probably something wrong with the logic board. This is not something that you will be able to fix. You will need to visit your nearest store or replace the GPS. See the Logic Board Replacement Guide for help.
Garmin Nuvi 1390LMT will not charge
You have plugged your GPS in and it is still not charging.
Wrong charger
You may have the wrong charger. To ensure you have the correct one, inspect the plug on both the charger and the GPS to see if they match. If you have confirmed you have the correct charger, and it is still not working, read on.
Battery/Charger connection
The battery may not be in the GPS correctly, try taking the battery out and putting it back in. The connection between the charger and GPS might have also been bad, unplug your GPS and plug it back in.
Broken charger
Clean the charger of all debris and check for any damage, then try plugging it back in. If that still does not work, the charger may be broken and you will have to replace it.
Dead battery
The battery may be completely dead and not able to hold a charge. You will need to replace your battery. See the Battery Replacement Guide for help.
Bad Outlet
Nothing may be wrong with the GPS. Try plugging the charger into another outlet, or flipping a switch to turn the outlet on.
Slow/Delayed Garmin Nuvi 1390LMT
The GPS is lagging on transitions and is not responding quickly to commands.
Overworking GPS
The GPS may be slow due to the amount of work it is trying to perform. Restart the GPS and try again.
Needs to be put back to “normal” settings
Restore GPS by resetting to factory defaults. Do this by going to the settings on the Nuvi, press “GPS Settings,” and then press “Restore Settings” and “Master reset.” (CAUTION: this will erase all current settings and restore it back to the original factory settings.)
Motherboard problem
If the GPS is still slow, there is probably something wrong with the network or motherboard.
Garmin Nuvi 1390LMT is Frozen
GPS is on, but is stuck on a screen and will not respond.
GPS needs to be restarted.
Try to restart the GPS touch and hold the bottom right of the screen while you turn the device on.
Motherboard
If this does not work then there is a problem with the Logic Board and will need to replace it. This is not something that you will be able to fix. You will need to visit your nearest store or replace the GPS. See the Logic Board Replacement Guide for help.
Broken Case
GPS case is cracked, scratched, and/or indented.
Replace
It is possible that the GPS was dropped causing the cracks, scratches, and/or indentations. Purchase a new case and replace the old case.
Garmin Nuvi 1390LMT is Unresponsive (buttons and screen)
Pushing buttons and/or using touch screen does not have the desired effect.
GPS is off
Before opening up your GPS, check that the GPS is turned on. Hold the power button for at least 5 seconds and wait for GPS to respond. If GPS remains unresponsive, read on.
Dead Battery
It is possible that the GPS’s battery has lost charge. Plug the GPS into a working outlet with the provided GPS charger to see if the GPS gives a response. If the GPS simply does not charge, the battery is dead and you must replace it. See the Battery Replacement Guide for help.
Broken Touch Screen
If there is a display but using the touch screen has no effect, try restarting the GPS. If the touch screen does not function upon restarting, test the touchscreen to see if the GPS is actually functioning. If the touchscreen still works, then the issue lies with the actual screen. See the Touch Screen Replacement Guide for help.
Black Screen
The screen does not display any images.
Brightness Settings
The black screen may actually just be a brightness setting. Move to a shaded area to see if the GPS has any display. If there is a slightly visible display, go to the tools menu on your GPS. Find the selection that reads Display and press enter this should lead you to a new submenu. Scroll down to find the option for backlight and adjust your brightness accordingly.
LCD Issues
If you move to a shaded area and the GPS (turned on) is still not showing any display, then it is a problem with the LCD. See the Touch Screen Replacement Guide for help.
Distorted Images/Random Color Arrangements
The GPS is on and the touchpad works, but the screen shows random color patterns or a distorted image.
Broken LCD
If the screen is not broken and shows color or distorted images when the GPS is on, the LCD below the screen is the likely location of damage. The LCD is likely to be cracked or broken and needs to be replaced. See the Touch Screen Replacement Guide for help.
Broken Screen
If the screen is physically cracked or broken and the LCD, audio, and touchscreen appear to work properly, then the screen needs to be replaced. See the Touch Screen Replacement Guide for help.
Reset Device
Try to restart the GPS touch and hold the bottom right of the screen while you turn the device on. Reconnect the device to a power source and turn it on. It should now be back to normal. Try plugging the device into a USB port on a computer again.
SD Card Reader Not Working
Can't read data from the SD card
Reinsert SD Card
Make sure that the SD card was inserted correctly. Remove it from the device and put it back in, making sure it is securely inside the card reader.
Broken SD Card
It is possible that the SD card is broken. Try using a different card if possible or use a different SD card reader on this one.
Broken SD Card Reader
If the problem is not the SD card, then the card reader itself on the device may be broken.
2 opmerkingen
The most common issue isn't even covered here. The USB charging connector in the GPS comes loose over time, and the charger eventually can't charge the GPS. It takes skill to fix this without breaking the GPS, but the fix is to take it apart and re-solder the 2 points that hold the GPS to the board. Note that the actual charging connections are not soldered but just press against the motherboard.
jbaker7 - Antwoord
cannot change city location
Chuck Parker - Antwoord
