Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
The Computer is Overheating
While you are using your device it feels way too hot to the touch, it is making loud noises, and/or it, without notification, shuts down.
Dust in the fan or vents
When excessive dust is in the fan or vents, the computer can overheat due to the lack of an adequate airflow. To fix this, you can take off the bottom back panel. Then using a compressed air duster or can, gently blow away the dust.
Broken Parts
If the fan itself is spinning excessively or not at all, the issue could be a damaged fan. A damaged fan involves stiff or missing blades. To fix this, it is recommended to replace the part. Using the User’s Manual, find the specific make of fan needed. Then it is recommended to go to an online retail site to buy the new fan.
Not Enough Thermal Paste
Thermal paste fills microscopic gaps between the heat sink and the computer’s CPU. If there is not enough thermal paste, the CPU’s heat is unable to escape. To fix this issue, you must first remove any old thermal paste, then put a new drop of thermal paste onto the CPU, then finally put the heat sink back into place.
No Hard Drive Detected After Replacing Drive
After the 7mm hard drive was just replaced, and the computer is saying nothings there.
Hard Drive Upside Down
The 7mm hard drive may be put in the wrong way. Begin by taking the 7mm hard drive out, flipping it onto the other side, and slide it back in. Test the issue by rebooting the computer and checking for the error again. If the error message persists, try another troubleshoot.
BIOS Boots Without Hard Drive
Try taking the 7mm hard drive out and booting to BIOS and diagnostics without one. If it is possible to boot to BIOS and diagnostics, this is an issue with the computer itself and not the hard drive.
BIOS Does Not Boot
Try taking the 7mm hard drive out and booting to BIOS and diagnostics without one. If it is not possible to boot to BIOS and diagnostics, then this is an issue with the system.
Dell Latitude E6530 Does Not Boot
The computer itself is not turning on.
Faulty Coil Cell Battery
Begin by powering the Dell Latitude E6530 off by holding the power button for 15 seconds to allow it to drain completely. Take the coil cell battery out of the Dell Latitude E6530. Wait 5 minutes or over night before putting the coil cell battery back in and turning the Dell Latitude E6530 on to see if the issue is resolved.
AC Adapter Not Working
Verify the AC adapter is working by connecting the Dell Latitude E6530 and AC adapter. Boot the Dell Latitude E6530 and open BIOS. Test the functionality by checking AC adapter under BIOS, if it reads “none,” ensure the connection. If it reads “unknown” then drain residual power in the device by holding power for 15 seconds, then turn the Dell Latitude E6530 back on and check BIOS again.
Battery Not Holding Charge
Restart the Dell Latitude E6530 and open BIOS, charge the Dell Latitude E6530 on BIOS.
Audio is not Playing
If your Latitude is not playing audio through its speakers or audio port there is likely a problem with the audio.
The BIOS is not updated
Updating the BIOS of your laptop frequently resolves software issues, including audio errors. Visit this website and follow the instructions to update your BIOS: https://www.dell.com/support/home/us/en/...
Ensure that all drivers are installed and updated
The device drivers are what control each device and allow them to function properly. Go to the windows search bar and type “Device Manager” and press enter. Right click the device, and select the option “Update Driver.”
The Speaker’s Connections are loose
If the issue persists, it may be a hardware problem. Please refer to the iFixit page on replacing the Dell Latitude e6530’s speaker to ensure that all the speakers connections are correct.
Touchpad is not Working:
The laptop refuses to accept input from the touchpad
The BIOS isn’t Updated
Update your system’s BIOS by visiting this link and following the instructions on screen:
The Drivers are not Updated
Many times an updated driver will fix the issue before you need to get your hands into the hardware itself. To update your device’s drivers type “Device Manager” into the windows search bar. Right click on the device and choose “Update Driver.”
The Issue Might be Hardware
If the issue still persists after these steps, you might need to physically repair the touchpad. You can access the touchpad by removing the keyboard. Please refer to the iFixit page on the Dell Latitude e6530 for physical repair help.
0 opmerkingen
