Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Touchscreen Not Responsive
You have trouble getting the touchscreen to work
Dirty/Wet Glass
Ensure that the glass is clean and dry, as this can interfere with the touch sensor. Simply wipe down the display with a clean rag or paper towel to remove any debris from it.
Software Issues
Sometimes performing a hard reset on your chromebook will fix many issues that cannot be fixed by a normal restart. To do this, first turn the device off. Next, press the refresh button and the power button at the same time. If the problem isn’t fixed, check for updates from google for your chromebook’s operating system. If there are none, or if the problem still isn’t fixed, then a factory reset might be necessary. Make sure all of your files are backed up to the cloud, then go to Settings > Advanced Settings > Powerwash. This will delete all of your personal data and settings on the device, making it just like when you bought it from the store. If this doesn't fix the problem, it's likely that it’s an issue with hardware, which can only be fixed with a screen replacement.
Weak Speakers
You have trouble listening to sounds on your computer.
Faulty Volume Controls
Make sure you don’t have the volume muted or have low volume settings. If you have muted your laptop simply press the mute button to unmute it. Click the volume icon in the system tray(bottom right) to turn up/down the volume.
Cluttered Cache
Clearing the cache can resolve some audio issues. Click on settings> tools>clear browsing data. Make sure only empty the cache is selected and specify that you want to clear information from the beginning of time.
Incorrect Settings
Turn off your chromebook and then turn it back on. At the login select browse as a guest. This allows you to run the chromebook without any special settings. If it works then there is some broken setting in your normal login. To fix this reset your chromebook.
Monitor Fails to Stay Open
You have trouble getting your laptop to stay in the tent mode or getting the screen to stay at a 90 degree angle.
Broken Hinge Casing
Most of the time the hinge on a computer is made out of plastic and is prone the cracking. Fold the laptop screen in all different directions and examine every angle of the hinge casing to ensure that there are no crack on it. This will either eliminate the possibility of replacing the hinge, or it will tell you that you need to replace your hinge to get it to stay in all positions again.
Faulty Screws
The hinge connects to the computer with two hinges, one on each side of the computer. Since this laptop can perform tent mode and turn into a tablet, a lot of stress is put on these hinges. Check these hinges and pull out each screw if possible. Check and see if any of the screws are loose and tighten them back up if possible.
Chromebook Will Not Charge
You have trouble powering on your laptop
Loose Connection
Make sure the charger is securely connected to the chromebook and to a working outlet. If there is no charge, the charger may be malfunctioning and you could need a new one.
Cluttered Battery Port
There may be dirt and dust in the charging port. Use compressed air to clean the port.
Faulty Battery
If the chromebook works fine when it is plugged in but turns off when it is unplugged, then it is the battery. Also, if the other troubleshooting techniques did not work, then you may need to replace the battery itself.
3 opmerkingen
bonjour est ce possible de changer les 32 go de memoire emmc par un ssd
merci
JEAN YVES GLOUX - Antwoord
Hello everyone,
I've had my Acer CB5 312T for four years. In that time my wife has broken the screen making the touchscreen click everything until I disabled it. It's been dropped countless times, countless spills and bends. But until now, no real problems. Now she won't charge from the low power phone charger, nor the original. I know that both chargers are working and that it's likely an internal connection issue. Trying the 6 hour power down and charge before I open her up. Any additional info welcome.
Kye Rafferty - Antwoord
is there a reason for the power light and charging light to be going back and forth and the laptop won’t charge no matter what, i’ve tried many things but nothing seems to work, unless i’m doing something wrong and should really go get it checked
the E7ERNAL - Antwoord
