Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Screen is unresponsive
The display is not responsive or has a static image
Bad Display
Try plugging in an external monitor. If the picture on the external monitor is normal but the display on the laptop is not, then the display on the laptop is bad and will need to be replaced.
Slow System
If the display looks normal but is just not responding quickly, then the operating system on the laptop is running slowly.
Fan is making loud noises
Your computer’s cooling fan is consistently on the highest fan speed
Debris in Cooling Vents
The most common cause is that the cooling fan is obstructed with debris, most commonly being dust. A quick blast of compressed air will clear any obstructions from the fan, allowing for better airflow throughout the system. How to clean the cooling fan
If the fan is clean but is still running loudly, then there must be an intensive process running on the system. You will need to view the processes on the computer and determine which one is the culprit.
Laptop is running slowly
Your laptop is being unresponsive or programs are crashing often
Possible Malware
There might be a computer virus or a bad program on your system. Make sure to run antivirus or antimalware software on the computer in safe mode and check if it identifies any threats.
Bad Operating System
Try booting windows from a usb, or try booting the device in windows recovery mode, and try to repair the disk. If that fails, then you can try and reinstall the operating system from windows recovery mode.
Not enough RAM
If the amount of memory in the system does not or barely meets the minimum requirements of the operating system, then the RAM needs to be upgraded. With more memory, the system should run smoother.
Bad Hard Drive
The hard drive may be corrupted. If the hard drive is corrupted, then you need to replace it with any 2.5in SATA Hard drive, or any 2.5in Solid State Drive. Failing Hard drives can can cause the device to run slow, eventually leading to the failure of the drive. One indicator of a failing drive is the drive getting loud, or making clicking sounds. If you hear your drive making sounds, or sounding loud, backup your data immediately and replace the hard drive.
Laptop has a slow start
Your computer takes a long time to boot from being off
Faulty RAM
The RAM used in the laptop may be defective. To test the memory, go to the BIOS and select an option that tests the memory. This test could take a while to complete. If the results claim that there is an issue in the memory, then the RAM will need to be replaced.
Faulty Motherboard
If fixing the RAM does not fix the issue, the you need to replace your motherboard. Ensure that you purchase the correct motherboard for your device.
Laptop doesn't charge
Your computer turns off immediately when the charging cable is unplugged
Missing Battery
Make sure that the battery is present and connected to the laptop.
Faulty Battery
If the battery is present in the laptop, but is not recognized by the computer, then it isn’t connected to the laptop. If the battery is recognized by the computer, then the battery is faulty and must be replaced. Batteries lose their effectiveness over time. In either case, the battery will need to be replaced.
Faulty Power Adapter
If your power adapter is bad, then the computer will only use the battery for power without charging. Borrow a power adapter or purchase another one and see if that fixes the problem.
0 opmerkingen
