Ga door naar hoofdinhoud
Lenovo Yoga 720 SSD Replacement
Wat je nodig hebt
  1. Lenovo Yoga 720 SSD Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    T5 Torx Screwdriver
    $5.49
    Koop
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 SSD Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement: stap 2, afbeelding 3 van 3
    iFixit Opening Tool
    $1.99
    Koop
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 SSD Replacement: stap 3, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement: stap 3, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement: stap 3, afbeelding 3 van 3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720 SSD Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement, Battery: stap 4, afbeelding 3 van 3
    JIS Driver Set
    $19.99
    Koop
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720 SSD Replacement: stap 5, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement: stap 5, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement: stap 5, afbeelding 3 van 3
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  6. Lenovo Yoga 720 SSD Replacement, SSD: stap 6, afbeelding 1 van 3 Lenovo Yoga 720 SSD Replacement, SSD: stap 6, afbeelding 2 van 3 Lenovo Yoga 720 SSD Replacement, SSD: stap 6, afbeelding 3 van 3
    • This is the SSD
    • remove the warranty sticker
    • Removing the warranty sticker and placing it back after may still void your warranty.
    • Remove 1 J1 Screw holding the SSD Remove the screw holding the SSD.
    • Update! I removed the size due to a lot of people having issue with stripping the screw when using the suggested size. I will look at this again when I have time. sorry for the inconvenience this caused many of you. use what you think works best here.
  7. Lenovo Yoga 720 SSD Replacement: stap 7, afbeelding 1 van 2 Lenovo Yoga 720 SSD Replacement: stap 7, afbeelding 2 van 2
    • Slightly lift the rear of the SSD
    • If you lift too far you could damage the motherboard connector or the SSD.
    • Gently pull it out.
Conclusie
22 andere personen hebben deze handleiding voltooid.
Aiden
17.429 Reputatie
21 handleidingen geschreven
12 opmerkingen
Your lucky to have a M.2 ssd. Also take those labels off if your going to have it serviced they may think you have opened it.
Padraic Hoselton - Antwoord
@captainsnowball 6000 REP! NICE.
Padraic Hoselton -
Thanks @paperboypaddy. those labels were always on it. I do need it serviced now though.
Aiden -
I was able to take off the battery. But I stripped the screw for the ssd. It would not come out. I used what I thought was the correct screwdriver. Can any help me?
Thank you,
Alberto
Email: defdasm@yahoo.com
Alberto Loya - Antwoord
Stripping the screw usually only happens if a] you’re using a screwdriver that’s the wrong size, or b] you aren’t applying sufficient pressure. You may be able to remove the screw by using some fine/needlenose pliers, but I’d urge caution in doing so, and you might want to take this somewhere to have it done professionally if you’re at all uncomfortable doing so safely. Once you’ve loosened it, remove it by hand if possible.
Also, I’d recommend you replace the screw while you have the case apart. It is most likely a metric, m2 (as in, m1, m2, m3, etc. unrelated to the M.2 SSD form factor) x 3mm long, though the length may vary by about 0.5mm. You can sometimes find these at local hardware stores like Ace or a locally-owned non-Ace store. Larger hardware stores like Home Depot or Lowes (in the US) are less likely to carry metric screws that small.
OwThatHertz -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 118
Altijd: 22,932
