Ga door naar hoofdinhoud
How to Reuse Dry Nail Polish
Wat je nodig hebt
  1. How to Reuse Dry Nail Polish, How to Reuse Dry Nail Polish: stap 1, afbeelding 1 van 1
    • Find a clean workplace where you can easily clean up spills.
    • DO NOT USE ACETONE TO THIN THE NAIL POLISH. Acetone is a solvent for removing nail polish. It can make the nail polish work but, the end result is dull or lumpy nail polish.
    • You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
  2. How to Reuse Dry Nail Polish: stap 2, afbeelding 1 van 2 How to Reuse Dry Nail Polish: stap 2, afbeelding 2 van 2
    • Open the bottle of dry nail polish setting the brush to the side.
    • Open the bottle of nail polish thinner.
    • Squirt 2 drops of nail polish thinner into the dry nail polish.
    • Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
    • Be careful to not not spill any nail polish thinner.
  3. How to Reuse Dry Nail Polish: stap 3, afbeelding 1 van 2 How to Reuse Dry Nail Polish: stap 3, afbeelding 2 van 2
    • If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
    • Do not apply too much nail polish thinner, this will result in watery nail polish.
Conclusie
The nail polish should reach its regular consistency after applying the nail thinner. You may then be able to apply your nail polish onto your nails.
6 andere personen hebben deze handleiding voltooid.
Iridian Vaca
289 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-5, Green Spring 2015 Lid van Cal Poly, Team 28-5, Green Spring 2015
CPSU-GREEN-S15S28G5
3 Leden
10 handleidingen geschreven
Één opmerking
If the nail polish is just thick, you can run hot water over the bottle for a few minutes to thin it down some. You don't want to shake a bottle of nail polish to mix it, it can put air bubbles in the mixture, instead roll the bottle between your hands. Nice first guide, GL here.
ABCellars - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 26,090
