Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iPod Shuffle 2nd Generation te repareren, gebruik onze reparatiehandleidingen.
  1. iPod Shuffle 2nd Generation Teardown, Teardown: stap 1, afbeelding 1 van 1
    • Packaging is virtually identical to the iPod Nano G2 packaging.
    • Included: Shuffle, color manual, USB 2 dock, and earbuds (plus spare earbud covers).
    • There are LEDs on top and bottom of the shuffle. You can't see both at once and they both flash the same messages.
  2. iPod Shuffle 2nd Generation Teardown: stap 2, afbeelding 1 van 1
    • The back of the Shuffle says: Model No.:A1204 EMC No.: 2125 5V 1A.
    • Let's take it apart!
    • The top and bottom of the shuffle have white plastic caps held on by mild adhesive. Heat the caps with a hair dryer and gently pry them both up. Make sure you don't pry the metal beneath the caps up at the same time.
  3. iPod Shuffle 2nd Generation Teardown: stap 3, afbeelding 1 van 1
    • Remove the shuffle / loop switch and the power switch.
    • The shuffle / loop switch is actually a metal arm about .5" long that extends along the bottom to a switch on the logic board in the center of the shuffle.
  4. iPod Shuffle 2nd Generation Teardown: stap 4, afbeelding 1 van 1
    • Beneath each cap is a metal retaining bracket.
    • Remove the two Phillips #00 screws on the top of the Shuffle and another two on the bottom.
  5. iPod Shuffle 2nd Generation Teardown: stap 5, afbeelding 1 van 1
    • Use a spudger to lift out the metal retaining brackets on either side of the Shuffle. The hinge side contains a tiny extension that supports the casing, so start from the other side (as shown).
    • Apple includes a 'flash guide' with ten different codes. The LEDs flash green, amber, and red.
  6. iPod Shuffle 2nd Generation Teardown: stap 6, afbeelding 1 van 1
    • Use a spudger to push the logic board through the case and out of the Shuffle.
    I wasn’t successful duing this step :(
    lavygames - Antwoord
  7. iPod Shuffle 2nd Generation Teardown: stap 7, afbeelding 1 van 1
    • The top of the logic board.
    • You can see the five button sensors, Apple logo ARM chip, and data ribbon cable (this leads to the headphone / dock jack on the other side)
    • The ARM chip has the numbers: 337S3300 844A N05WDK01 0642 ARM.
    • There's a smaller chip to the left of the Apple logo chip that simply says 'AAC.'
  8. iPod Shuffle 2nd Generation Teardown: stap 8, afbeelding 1 van 1
    • The bottom of the logic board.
    • Apple has done an impressive job of packing functionality into the headphone jack. The dock plug has three conductive strips, plus the ground post. It's safe to assume that the plug is multi-modal and switches between USB, analog audio, and possibly power modes. The separate power mode may not be necessary if they can get enough juice off a 4 conductor USB connection.
    • It should be easy for a third-party developer to make a small USB adapter that restores the memory-stick functionality of the Shuffle.
  9. iPod Shuffle 2nd Generation Teardown: stap 9, afbeelding 1 van 1
    • Battery flipped out
    • Notable features: Li-ion polymer battery (this is soldered onto the logic board), headphone / dock / power jack, and memory chip (hidden beneath the headphone jack.
  10. iPod Shuffle 2nd Generation Teardown: stap 10, afbeelding 1 van 1
    • The disassembled shuffle.
    • On the left, from top to bottom: shuffle / loop and power switches; bottom and top caps and metal brackets; four Phillips #00 retaining screws.
    • On the right: battery and logic board; case with electronics removed.
    • The case appears to be one piece of molded Aluminum. It feels sturdy.
  11. iPod Shuffle 2nd Generation Teardown: stap 11, afbeelding 1 van 1
    • Shameless plug:
    • iFixit sells iPod parts. It's easy to fix an iPod yourself with our iPod parts and free iPod repair guides.
    • We also sell Mac laptop parts. We've got virtually any part or upgrade for an iBook, PowerBook, MacBook, or MacBook Pro at very competitive prices.
iRobot
1 Reputatie
636 handleidingen geschreven
3 opmerkingen
There are two white clips to be removed. They hold the logic board to the case. This step should be inserted between step 5 and 6.
Alice - Antwoord
Did not see any such ‘clips’ that prevented the insides being removed from the case.
doctordon - Antwoord
happy happy happy.
kenneth krabat - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 207
Altijd: 262,645
