Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iPod Nano 5th Generation te repareren, gebruik onze reparatiehandleidingen.
  1. iPod Nano 5th Generation Teardown, iPod Nano 5th Generation Teardown: stap 1, afbeelding 1 van 2 iPod Nano 5th Generation Teardown, iPod Nano 5th Generation Teardown: stap 1, afbeelding 2 van 2
    • Apple's got a routine going with the nano. Never fail, come September, we get a new one.
    • 1G - September 7, 2005
    • 2G - September 12, 2006
    • 3G - September 5, 2007
    • 4G - September 9, 2008
    • 5G - September 9, 2009
    • This is the first time Apple's had a similar exterior design two releases in a row. The rear-mounted video camera is the only clear sign that we have a new device in our hands.
    • Notice the white wrapper around the packaging. Not even Apple employees got to sneak a peek at this one.
    iPods have come wrapped in that white wrapper for a while now - thats nothing new. It prevents the cases from getting scratched in transit.
    warren602 - Antwoord
  2. iPod Nano 5th Generation Teardown: stap 2, afbeelding 1 van 1
    • Shiny!
    • Many of the new features include a pedometer, voice recorder, voiceover, a genius mix feature, FM radio, a speaker, oh, and a little thing called a VIDEO CAMERA!
    • The one thing the nano didn't receive this release is a capacity upgrade. Like the 4th Gen, this nano comes in 8 and 16 GB capacities.
    • You can [www.twitter.com/ifixit|follow us on twitter] to get all the latest updates as we're doing the teardown!
    Where's the speaker?
    imixx - Antwoord
    Citaat van imixx:
    The speaker is shown in Step 14. It looks like it's one of these: http://www.murata.com/products/article/p... (or equivalent.)
    sendai - Antwoord
  3. iPod Nano 5th Generation Teardown: stap 3, afbeelding 1 van 1
    • A video camera finally comes to the iPod line. Surprisingly, it's in the nano, and not the touch.
    • According to Apple, the video camera offers:
    • H.264 VGA video
    • 640 by 480 pixels
    • Up to 30 frames per second
    • AAC audio
    • Can you take photos? NO. There is no still camera option in the nano 5th Generation probably due to the low resolution of the VGA camera.
  4. iPod Nano 5th Generation Teardown: stap 4, afbeelding 1 van 2 iPod Nano 5th Generation Teardown: stap 4, afbeelding 2 van 2
    • A Plastic Opening Tool makes quick work of the plastic bezel surrounding the dock connector.
    • There's not much to see here yet. We're working on getting to the good stuff...
    • So far, there's a lot in common with the 4th Gen nano.
  5. iPod Nano 5th Generation Teardown: stap 5, afbeelding 1 van 3 iPod Nano 5th Generation Teardown: stap 5, afbeelding 2 van 3 iPod Nano 5th Generation Teardown: stap 5, afbeelding 3 van 3
    • No surprises here. This design is identical to the 4th Gen nano. Even though the exterior hold switch is near the edge of the iPod, the internal hold switch is actually in the center of the iPod.
    • Shameless plug: We sell hundreds of iPod parts for repairing your iPod nano or replacing an aging iPod battery.
    I'll say the switch at the center is catered for future thinning of the nano.
    Zea - Antwoord
  6. iPod Nano 5th Generation Teardown: stap 6, afbeelding 1 van 2 iPod Nano 5th Generation Teardown: stap 6, afbeelding 2 van 2
    • Unlike some earlier iPods, the hold switch isn't directly attached to the logic board.
    • That's a really thin ribbon cable. Then again, there's not a lot of data that needs to go through it.
    Make sure the remove the base plate by removing the very small screws. Which make Step 10 (later on) much more easy.
    Rick van der Zwet - Antwoord
    Where can i get a new ribbon?
    pskaist - Antwoord
    Take great care with the hold switch ribbon cable. I've broken two up to now. It has the strength of a piece of 2mm wide bathroom tisue. Also has a right angle bend so it willl tear more easily. You will find two very small screws holding the switch to the small metal bracket. Don't remove them - just slacken them and slip the switch off as the holes are slotted. This frees the large metal top piece and you have less weight hanging on that ribbon. Incidentally, if you do have the bad luck to tear the cable all is not lost as the lock position is with the switch closed (shorted).
    Pete Green - Antwoord
  7. iPod Nano 5th Generation Teardown: stap 7, afbeelding 1 van 2 iPod Nano 5th Generation Teardown: stap 7, afbeelding 2 van 2
    • The camera bezel appears to be keeping the iPod's insides from coming out.
    • Eine Deutsche Rasierklinge should fix that...
    • The microphone by the camera ensures you get sound with your VGA moving pictures.
    • Use a pin to remove the small white retainer from between the camera and microphone holes. This keeps the components from sliding toward the bottom of the nano.
    It's Hobelklinge ;))))
    mac605 - Antwoord
    and it's Deutsche
    DavidL - Antwoord
    Citaat van DavidL:
    and it's Deutsche
    actually it should say: Eine deutsche Rasierklinge should fix that... ;)
    docmeth02 - Antwoord
    Actually, it's a German fad blade to remove callus from your feet.
    Sebastian H - Antwoord
    Is it necessary to remove the lens cover to remove the body?
    Abhishek Hardas - Antwoord
  8. iPod Nano 5th Generation Teardown: stap 8, afbeelding 1 van 2 iPod Nano 5th Generation Teardown: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Spudger
    $3.99
    Koop
    • Apple has redesigned the click wheel on this nano. Instead of being (fairly permanently) affixed to the case, we were able to rotate and lift the click wheel.
    • You can use a spudger to completely remove the click wheel without taking the rest of the iPod apart.
    How exactly is the click wheel removed? You have to rotate it left or right before it lifts off? Does it lift off easy or does it snap/pop off?
    Phillip Clark - Antwoord
    Citaat van Phillip Clark:
    No rotation possible as I far could see, glue to keep it in place. And a very small clip hidden behind the play/pause button
    It is not removed by rotation. There are two spots holding it in, one on the top (menu) and one on the bottom (play/pause). The one on the bottom is put underneath the rectangular protrusion from the bottom metal bezel (the thing around the dock connector). Once you remove the metal bezel, then the click wheel should just lift out, although like Rick said there is a small amount of glue so you may need to use a spudger.
    Andrew Marshall -
    Click wheel: I have found traces of adhesive here on a metal rim about 0.5mm wide which is part of the machined case. This rim is then cut away into four 1cm long pieces. One at 10 oclock, 4 oclock, 8 oclock and so on. Not much adhesive - but don't underestimate - it's very strong stuff. At the top of the clickwheel (at 12 oclock) is a small metal tab which slides under the ipod body. When prying out the clickwheel, lift from the bottom, otherwise you are pulling against this metal tab as well as the adhesive. Some heat on this area helps to release the adhesive. Don't end up with the metal plate under the clickwheel looking like a potato chip as happpend with my first teardown.
  9. iPod Nano 5th Generation Teardown: stap 9, afbeelding 1 van 1
    • There's a thick slab of glass covering the LCD. Unlike the iPhone, we haven't seen issues with broken glass on the nanos.
    • If you want your screen to look nice, don't touch it. Fingerprints are quite noticeable on the glass.
    Does anyone know where you could get the glass replaced, my had what looked to be a scratch went to rub off and the glass shattered/cracked, and of course being the consumer and customer I'm out of luck apparently....
    angi - Antwoord
    Hey there.
    We have a new nano 5g, now with broken glass. It was just a small drop at the sidewalk and the glass went broken.
    Do you know where we kan geet a new glass?
    Lennart
    LennartT - Antwoord
    Removing will be much more easier if your first use step 10 to push the internals out a small bit and than gentely push the window out at the upper edges from inside out.
    To take off the glass, do we do it similarly to the 4th gen nano, where you just push it towards the clickwheel a bit to loosen the top first? or is a different method better here?
    iTronics Repair - Antwoord
    Can you only get the glass off by taking apart the rest of it?
    Patrick Lajeunesse - Antwoord
    Is it necessary to remove the glass to remove the body? Can it be left as it is?
  10. iPod Nano 5th Generation Teardown: stap 10, afbeelding 1 van 1
    • Removing the internals... It's a tight squeeze, but we got them out. Getting this iPod open wasn't easy. We don't recommend trying this at home. Take great care not to scratch the screen on the sharp recess for the click wheel, bend up slightly if necessary.
    • We wish Apple would put a little effort into making iPods repairable, instead of forcing people to throw them away when they break. Recent iPods have become increasingly difficult to successfully repair.
    • This iPod employs copious amounts of glue and adhesive to hold everything together. That makes it easy for Apple to put together, but hard to take apart.
    Any idea whether the adhesives and glues used in the Nano are designed to withstand repeated exposure to high humidity as often happens when people strap the device against their body while exercising? I owned a Nano Gen 3 that stopped working after only a couple months. Other people at my gym using their Nano the same way I do reported the same problem with their Gen 3. I never had problems with the Gen 1 or 2 and have no experience with Gen 4.
    billyg - Antwoord
    You don't have to throw away an old iPod...you can use the Apple Recycling Program and take your iPod to a retail store and trade it in and get 10% off your new iPod...as long its got nothing wrong with the battery...
    Lumpy - Antwoord
    Made sure to protect your ribbon cables from breaking from the sharp metal edges of the clickwheel using a small piece of hard plastic (plectrum for example)
    1 MAJOR step is missing. You must use a metallic spudger tu unstuck the battery witch is glued to the back of the case. There is a small patch of glue located 1 cm from the top of the ipod.
    frde - Antwoord
  11. iPod Nano 5th Generation Teardown: stap 11, afbeelding 1 van 1
    • iPod, sans casing.
    • The tolerances on this iPod are incredibly tight, there's no wasted space inside.
    Missing a step on how-to remove the metal frame. Takes a fairly bit of effort to disassembly all attached objects of the frame before you are able to lift the 'mainboard' with battery attached out of it.
  12. iPod Nano 5th Generation Teardown: stap 12, afbeelding 1 van 1
    • The new nano features a larger display (2.2" and 240x376). This is the same width as the 4th Generation nano, but 56 pixels taller. On a pixel basis, that's 17.5% more screen real estate.
    • Apple keeps putting bigger screens in the same size devices. The footprint of the iPod nano has stayed the same over the last four years, but this display has four times the pixels of the original nano.
    anyone know how to replace the backlight? is it possible?
    dave - Antwoord
  13. iPod Nano 5th Generation Teardown: stap 13, afbeelding 1 van 1
    • The battery. Apple warns you right from the get-go that your iPod may melt and/or spontaneously combust: "Potential for fire or buring." We assume they mean burning. It is assembled in China, so we'll give them a little slack.
    • Supposedly if you burn this battery, it will burn.
    It actually has a typo: "Potential for fire or buring.".
    nneonneo - Antwoord
    Citaat van nneonneo:
    Cutting these batteries with a sharp knife produces neat looking sparks all around the blade. Between the layers of the foil in the battery is a clear slimy/lumpy substance, akin to semi dried alcohol hand sanitizer.
    sflaig - Antwoord
    Where can I get a replacement battery? Anyone? It doesn't look like I can use 4th generation battery. Although the voltage is same, the connectors are different
    Eric - Antwoord
  14. iPod Nano 5th Generation Teardown: stap 14, afbeelding 1 van 1
    • Here's the speaker. Like the Touch 2nd Gen, the audio simply comes out the bottom of the iPod.
    • For something only about a millimeter thick, it's not really fair to complain about audio quality.
  15. iPod Nano 5th Generation Teardown: stap 15, afbeelding 1 van 1
    • Removing the connector that connects the microphone, speaker, hold switch, and headphone jack to the logic board.
    where's the pic of the front of the camera? ? ? ? ?
    kyletallent - Antwoord
    that space for the microphone by the camera looks really tiny. what kind of microphone is it?
    fdsa - Antwoord
    Citaat van kyletallent:
    The 'front' of the camera, and the microphone is shown with the speaker in Step 14. They are the two padded components at the bottom.
    sendai - Antwoord
    Where are the water contact indicators in the 5G? Are they the white dots seen in some of these steps? I know there's one in the headphone jack, but I have yet to see a picture of it to compare mine too.
    Corey - Antwoord
  16. iPod Nano 5th Generation Teardown: stap 16, afbeelding 1 van 1
    • Removing the camera.
    • It's nice to see that the camera's a separate module and not integrated into the board.
    interesting that the connector says "foxlink" as opposed to "foxconn"
    perhaps foxconn only handles the iphone?
    Omega192 - Antwoord
    Any one offer an extension cable for the camera so it can used in a more creative way?
    DrPepper1979 - Antwoord
  17. iPod Nano 5th Generation Teardown: stap 17, afbeelding 1 van 1
    • The camera, in all its VGA resolution glory. The camera itself is less than 3 mm thick.
    • Space may have been a factor in not including a better camera. Excluding its mount, the camera in the iPhone 3G is about 6 mm thick. The 5th Gen nano is 6.2 mm thick at its thickest point.
    • Unlike the nano, the touch, at 8.5 mm thick, could conceivably support an iPhone-sized camera, although it would certainly be an engineering challenge.
  18. iPod Nano 5th Generation Teardown: stap 18, afbeelding 1 van 1
    • In our iPod, Toshiba is the source for the 8 GB of flash memory. On the chip:
    • TH58NVG6D2ELA49
    • ID8038
    • TAIWAN
    • 09299AE
    • It looks like this was made in Taiwan in week 29 of 2009 (mid-July).
    • Also visible to the right of the Toshiba chip is the rubber mounting fixture for the camera, assumedly to dampen vibrations.
  19. iPod Nano 5th Generation Teardown: stap 19, afbeelding 1 van 1
    • The front of the logic board.
    • The main ARM processor dwarfs everything else on the board. Similar to previous iPods, we expect this is an Apple-branded Samsung processor.
    • Here's the markings from the processor:
    • 339S0081 ARM
    • K4X51323PG-UGC6
    • EDE168AG 0928
    • APL0378A00
    • N1X2XW 0931
    Watch out for that delicate connector directly left of the apple branded arm chip. Looks like, in the picture, it was broken in half during disassembly.
    jdcompman - Antwoord
    Citaat van jdcompman:
    EDIT: Easier to see in Step 20
    Yup, a word from the (recently) wise: remove the click wheel before you slide the internals out.
    Andrew Bookholt - Antwoord
    Citaat van andrew:
    Some of the "Tools" you use to disassemble an item with parts so small are really quite archaic. You should put in for some newer tools for finer work. IPO.
    egrau - Antwoord
    This is wonderful - thank you! Is there any sign of the size of the sensor on the camera? I can't find any specs on the basic Apple site.
    sleeper99 - Antwoord
    I was about to make the same comment, noticed that right away. It is a bit scary when even the experts have trouble opening these things intact 0.0 I guess Apple's so hellbent on making these things thinner they sacrifice serviceability. I wonder what their yields and raw production costs are like? Their computers are much easier to work on, even if the iMac does require a big suction cup to pull the glass panel off..
    WillyDavidK - Antwoord
    Do we have a chance to find out which chip is for the FM radio ? Is there a bluetooth ( for Nike? ) or Wi-Fi ( to upload video ) ?
    jerryfan - Antwoord
  20. iPod Nano 5th Generation Teardown: stap 20, afbeelding 1 van 1
    • The shiny chip is visible from this angle:
    • 338S0559
    • ATWV0926
    • SGP
  21. iPod Nano 5th Generation Teardown: stap 21, afbeelding 1 van 1
    • ~ The End ~
    • Credits:
    • Pictures and hardware analysis: iFixit
    • Flying to Pennsylvania to take apart the new iPod nano for you: iFixit's summer intern.
    • Want a programming job with us? We're hiring.
    Hey, but what about axelerometer? Apple was remove it from iPod nano 5G? Or we still can shake nano for next song?
    borshak - Antwoord
    3.5mm connector missing in final image?
    steveisteriffic - Antwoord
    Citaat van borshak:
    There has to be a way for the pedometer to work, right? It is still there.
    Joshrath - Antwoord
    Citaat van steveisteriffic:
    Nope, the board is upside down, so it is on the left of the dock connector.
    Joshrath - Antwoord
    Citaat van borshak:
    It's still in there, that's how the shake to shuffle feature works. Also, is can detect which way the ipod it turned and put video in that direction (left or right from its usual upright position), and it can decide whether to record video in portrait or landscape mode.
    shardsofmetal - Antwoord
    So what is the chip handling the communications for this machine?
    PeterG - Antwoord
15 opmerkingen
where's the FM radio?
stevev1 - Antwoord
Citaat van stevev1:
It uses the head phone wire because all u need is the right programming and a 2 foot wire to get radio
themassofthesun - Antwoord
Citaat van stevev1:
tha antenna is in the headphones
arintosh - Antwoord
i wish i could afford an ipod :(
illy305 - Antwoord
does any one have a spare ipod that you would be intrested in giving away please???? any type of ipod..
illy305 - Antwoord
Citaat van stevev1:
Techdude is very very mistaken. Its on the the small chip with the dot on the left side in the middle (vertically) in Step 18.
ufmeifu - Antwoord
What is that in step 18, could it be, a connection to get into the root of the OS, no not apple. (Sarcastic)
nav13eh - Antwoord
Where can I find a battery for 5th generation nano. It seems no one sells it. Why is that?
Eric - Antwoord
hey could you sell me an ipod nano 5th generation's display ??
Dewey - Antwoord
Yup, they can be found here.
Andrew Bookholt -
This tutorial explains nothing
zack - Antwoord
its not a tutorial if you need fix use the repair guide
bob boberson -
Hi, any idea where i can buy just the 338S0559 audio amplifier chip or if not can anybody point me to where i can buy a logic board with the IC on it?
Oliver Mardle - Antwoord
i don’t care if there’s anything missing here because,
1: i don’t have an ipod (because i’m poor af)
2: i just thought this was entertaining to read :D
btw you’re epic <3
Guy Smith - Antwoord
Can anyone put a new screen and battery in my 5th gen Ipod Nano?
Craig Cantrell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 255
Altijd: 530,515
