Gereedschappen die in deze demontage worden gebruikt
Inleiding
The mini has landed! It’s iPhone 12 teardown time—again—and while the phone may be small, this teardown is bigger than ever. It’s so big, we had to split it into two parts! We even dished on all the chips and other 5G hardware differences between the US version and those sold to our friends in the EU. (Yes, we tore down both.)
Meanwhile, we’re chasing a whale of a teardown week! Arm your harpoons and take a look at our Xbox Series X teardown, a side-by-side PlayStation 5/Xbox comparison, and oodles of live video teardowns. And if even that’s not quite big enough for you, check out the full iPhone 12 Pro Max teardown.
Feeling overwhelmed by all the new tech? Fix what matters instead! We’ve put together a list of our favorite gifts—from our workshop to yours, to help you and your favorite fixer keep the repair spirit going strong. Want some more community spirit? Keep up on our YouTube channel, Instagram, or Twitter for all the latest inside-out adventures—or sign up for our newsletter and always be in-the-know.
Sometimes big specs come in small packages, and that's certainly the case here. We grabbed both the US and EU models so as not to miss anything:
A14 Bionic with fourth-generation Neural Engine
5.4 inch (2340 × 1080 pixels) Super Retina XDR OLED display with True Tone and HDR
Dual 12 MP camera system with ultra-wide angle (ƒ/2.4) and wide angle (ƒ/1.6) cameras
64, 128, or 256 GB of storage
5G (sub-6 GHz and mmWave) connectivity, plus 4x4 MIMO LTE, 802.11ax Wi-Fi 6, Bluetooth 5.0, and ultra-wide band (UWB)
MagSafe 12 W wireless charging
IP68 rating, water resistant to a depth of 6 meters for up to 30 minutes
iPhones are fully onboard the "normal is big, and big is really big" train—despite continued calls for a return to the wee phones of yore.
Unfortunately, a return to a (slightly) smaller size doesn't mean a return of our friend the headphone jack. RIP to an OG.
The iPhone 12 mini does bring an interesting new feature: increased grille asymmetry (presumably to Jony Ive's chagrin). It appears that the smaller phone needs a little more space for that antenna band.
As is the case for the other iPhones 12, a small mmWave window on the side marks the US models, while the EU's feature some regulatory tribal tattoos.
iPhone design may change over the years, but the Pentalobe screws remain the same. Good thing our toolkits have all the bits you'll need.
Like its siblings, the iPhone 12 mini's display is held down by some tough adhesive. It's no match for some heat and the big
gunssuction cups. -
With the Pentalobe screws gone and the adhesive sliced, the display opens in the same lefty-loosey manner we've seen in the iPhone 12 and 12 Pro.
Alright, we're done with "Operation"—who wants to play a little "I spy"? Compared to the regular 12 we see:
Two display cables instead of three
A miniaturized battery, Taptic Engine, and loudspeaker
Some migrated display silicon
The upper sensor assembly, containing the speaker, Face ID, and sensors also got a rework to fit its slightly smaller home.
This is the first time we've seen "más" cameras in a "menos" iPhone. It's impressive to see, especially if no corners were cut in the process.
The mini camera (left) has the same ƒ/1.6 wide-angle and ƒ/2.4 ultra wide-angle cameras found in the regular iPhone 12 (right). The wide-angle module also features optical image stabilization (OIS)—and we have the X-rays to prove it!
Hi, any idea as to why the connectors are different if both are the same module? I mean, apart from needing space inside, what are the 12mini users sacrificing with the smaller connector.
I believe the difference is the optical image stabilization tech used in the larger iPhone 12
Dan -
Removing the speaker reveals the 12-series-standard (and festive) orange ingress-prevention gasket.
Considering the already shrunken Taptic Engines, we're surprised to see an even shrimpier one in this mini.
This tiny Taptic Engine measures 15.14 mm x 10.9 mm x 3.44 mm—25% smaller than the motor in the 12 and 12 Pro.
Taking advantage of that "extra" space: a beefier cable and socket.
Grab your tweezers and pull! These standard stretch release tabs are mighty big compared to their petite home, but we've got the muscle for this mini.
This mini battery packs a surprising 8.57 Wh. That's more juice than the iPhone SE 2020's 6.96 Wh, but understandably short of the 10.78 Wh of the standard 12 it's stacked on top of.
While its three bigger siblings offer 15 W wireless charging, the mini sips up juice at a slightly less thirsty 12 W.
We’re back after a much needed catnap! But superheroes never sleep—and Creative Electron has saved the day with this neat X-ray.
What can we learn? As usual, the dark bits are the dense, often magnetic parts of the phone, namely:
OIS magnets on the lower camera, earpiece, and loudspeakers, as well as the teeny Taptic Engine.
Perhaps most interestingly, we see the MagSafe ring has been miniaturized ... kinda.
But what are those dense spots in the upper sensor array? Time to investigate.
The US face-facing cameras are once again packing a little something extra where the EU edition was bare.
Their absence in the EU iPhone may suggest this is a third mmWave antenna of some sort (although it doesn't look like any mmWave antenna we're familiar with). We tried blasting it with X-rays, but it refused to talk.
It makes you wonder whether someone at Apple earned their paycheck for the year miniaturizing the ambient light sensor even further to free up this space. Where'd it go?
Let's check out these logic board sandwiches. For reference, the US version is on top in these images, EU below. (Don't read into it—that's just how the chips fell.)
First, the similarities—the US and EU upper sections are identical and have the same spread of chips on both sides.
The lower sections are a bit more interesting. (Note: SIM readers are the same, but we only desoldered it from the US version.) Here's where the US board starts accommodating all that mmWave tech:
An extra socket, which connects to the front mmWave antenna mentioned in the previous step
A Murata 1XR-482 mmWave front-end module
A Qualcomm SMR526 intermediate frequency IC, working in conjunction with Qualcomm's SDX55M 5G modem
One more mmWave antenna right on the board
A flex cable soldered to this patch, which connects to the side edge mmWave antenna
Are those 5G components so expensive as to justify two different versions of the board and the other differences between the US and EU variants? It seems to me that simpler would be better, with the exact same hardware and the functionality disabled in the OS for specific regions based on GPS location. It also would be more consumer friendly: what if someone travels from Europe to North America and wants to use 5G mmWave? Tough, you bought the EU variation without the required chips to do that.
After learning the finer points of US vs. EU sandwicherie, let's tuck into the (mostly familiar) US silicon layers:
Apple APL1W01 A14 Bionic SoC with Micron MT53D512M64D4UA-046 XT:F 4 GB LPDDR4 SDRAM layered over it (same as the iPhone 12/12 Pro)
1UED, most likely a U1 ultra-wideband chip similar to the USI chip in other iPhones
STMicroelectronics STWPA1-3033ABM wireless charging IC, possibly something similar to their STWBC-EP chip
KIC M224 BE0408 TWNA 12031, 64 GB of Kioxia NAND flash memory
Qualcomm SDR865 5G and LTE transceiver
Qualcomm SDX55M 5G modem-RF system and SMR526 intermediate frequency IC
Apple APL1094 power management IC
Thanks for pointing this out! We did know of this, but at some point, the pretty screenprinting overwhelmed our technical intuition. I’ll correct the bullet.
Processor PCB IC identification continued:
Texas Instruments SN2611A0 Li-Ion Battery Charger
Apple/Cirrus Logic 338S00537 Mono Audio Amplifier
Apple/Cirrus Logic Unknown Audio Codec
NXP Semiconductor CBTL1614A1 Display Port Multiplexer
Samsung S2DOS24 Display Power Management
Apple 338S00564-B0 ? Power Management
Texas Instruments LM3562A1 LED Driver
What is the red IC? Is it Texas Instrument Tigris Battery Charger SN2611A0 ?
And a little more US silicon:
Murata 583 and Skyworks 53807 diversity receive modules
USI 339S00761 WLAN / Bluetooth module
Qualcomm PMX55 power management IC
Avago 8200 high/mid-band power amplifier with integrated duplexer
Skyworks 5824x power amplifiers
Broadcom BCM15960A0
Sort of confused about the BCM15960A0 - why would Apple need a prefix-search/indexed database coprocessor of this size in an iPhone? These are usually used for IP routing at extremely high (100gbit+) speeds using large rules tables, like you’d see in commercial grade routers or switching equipment.
Furthermore, why would it be isolated in such a way on the board - and not present in any other model?
Agreed, I don’t think the linked datasheet has/had any relationship to what’s in the teardown. Removed.
Like the day after Thanksgiving, we pick from the leftovers sitting in the
fridgecase. -
We pilfer some ribbon cables, antennas, microphones, the flash module, and the Lightning connector.
Emulating its larger brethren, the last component that comes up is the MagSafe coil & button assembly.
The iPhone 12 mini is a small phone with big ambitions. We're surprised by how familiar the internals look compared to other iPhones this year, given the differences in size among them.
Miniaturizing components like the speaker and Taptic Engine conserves some space, but battery capacity still takes an unfortunate hit.
Last but not least, does the mini manage to score big on our repairability scale? Keep scrolling to find out.
- The two most common smartphone repairs—display and battery—are well-prioritized here.
- Most major components are modular enough to be accessed/replaced independently.
- Specialized screws complicate repairs, but remain preferable to overuse of glue.
- Waterproofing measures make many repairs more difficult, but safeguard against (extremely difficult) water damage repairs.
- Glass covering the rear housing is fragile and impractical to replace—a single drop could necessitate replacing the entire body of the iPhone.
Laatste gedachten
Repareerbaarheidsscore
(10 is gemakkelijkst te repareren)
7 Opmerkingen
I wonder how Apple manages to keep thermals under control. Usually, the top of the SoC is cooled in most phones, but it looks like the only method of cooling this device is through the back of the logic board. I know it works, but it just doesn’t seem like the best solution.
The Node level used in creating the A14 uses much smaller lithography widths (5 nm) than other SoC’s so the chip runs cooler!
Dan -
Great effort, thx. Will we get some teardown wallpaper for the 12 mini?
Definitely! Stay tuned for some wallpapers!
