Inleiding
You probably expected a thinner, lighter, and faster iPad Air 3, but Apple had other ideas. Instead of iterating on October 2014's iPad Air 2, they went back to the drawing board. Actually they probably don't use a drawing board, they use an iPad Pro—which might be where they got the idea for this. It seems to pack all the features of the first iPad Pro, in a smaller package. Let's see how they did it—it's time to tear down the iPad Pro 9.7".
Follow us on Facebook, Instagram, or Twitter for the latest teardown news.
Wat je nodig hebt
Video overzicht
Apple may have let all the Air out of the iPad line, but they didn't skimp on the 9.7" Pro's specs:
Fully laminated, 9.7", LED-backlit, Oxide TFT "True Tone" display with 2048 x 1536 resolution (264 ppi)
3rd generation 64-bit Apple A9X custom processor, with M9 motion coprocessor
12 MP rear iSight camera with 4K video recording at 30 fps, and 5 MP FaceTime camera with 720p video
Self-balancing, four-speaker audio
Touch ID sensor, 2 microphones, 2 ambient light sensors, accelerometer, barometer, and 3-axis gyro
802.11a/b/g/n/ac MIMO Wi-Fi + Bluetooth 4.2
32, 128, or 256 GB of on-board storage
Before sinking our
teethpicks into this thing, we check out our favorite website to get a look at the True Tone display. -
Of course, what sleek, new mobile offering out of Cupertino would be complete without the infamous camera bump?
And, for the second time this week, the Rose Gold rear case shows off a new model number: A1673, and the usual regulatory markings.
No surprise, once it reaches its 5th birthday, Apple doesn't want you pitching your iPad into the nearest trash can—they'd prefer you give it back.
The whole iPad family is here! Left to right: Mini 3, Air 2, and iPad Pro 12.9".
Truly, in its entire history, there has never been a more Rose Gold iPad than this.
In all seriousness, it's refreshing to see a redesign that seems to focus on features rather than a nigh-pointless reduction in thickness, in a device that's already thinner than a pencil.
Our ingenious friends at Creative Electron sent us a sneak peek at the Pro 9.7's internals, X-ray style.
We immediately note that where the larger iPad Pro's interior volume was dominated by four huge speaker enclosures, this little guy uses a more conventional setup: the battery hogs most of the space, with the logic board on the side and the speakers squeezed in at the margins.
What's that weird strip of PCB running through the middle, though?
Time for a closer look. Let's open it up!
As we heat up the iOpeners, we place bets in the office pool: Where will the display cables be this time?
Time to pick softly and hope we don't snag anything.
Having successfully carved the front panel free from its gluey frame, we get our first peek inside...
Survey says: Display cable's in the bottom right corner! That's a new configuration.
We'd like to take a brief moment to mention that disassembly instructions are hugely important for successful repairs. We believe every user has the right to know how to safely work on their device.
The display, backed with some cushioning foam, also contains a ton of chips!
Parade Technologies DP815 (likely an iteration of the DP695 timing controller found in the 12.9" Pro)
NXP Semiconductors 8416A1 (NVT8416) secure microcontroller (for Touch ID)
Renesas ISL98667A display power management
Gereedschap gebruikt in deze stap:Battery Blocker$3.99
After popping a few screws, we remove a big slab of EMI shield covering the logic board.
Our fingers are itching for chips, but for now we restrain ourselves and settle for isolating the battery. One precisely-placed pick separates the battery contacts from the logic board.
Next to come off is another shield covering the battery board, nestled between the two large battery cells.
With shields and tape deftly dispatched, we turn our attention to the heavy hitters. First up: upper speakers!
They're really fiercely glued in, and screwed in, but it's nothing a plastic opening tool can't deal with.
Once we pop the speakers out for a closer look, we're rewarded for our hard work: they connect to the logic board with spring contacts!
Attached to the top right portion of the speaker is what looks like a proximity sensor who's flex cable is also the power button and flash. I accidentally ripped mine while prying speakers up since I didn't know. The cable is separate from the speaker, but the proximity sensor part of the cable rests on top of speaker, adhered down. Remove sensor from speaker prior to removing speaker itself.
Good to know. Thanks Edgar
Pretty disappointed with this guide for multiple reasons but this one was the last straw. I’ve done every Apple device tear down many many times but this model was the only one I haven’t. I usually don’t look at the members comments because either these guides are correct or it’s self explanatory. Well, this one you absolutely dropped the ball! I as well tore off the proximity sensor cable because in no step or pic had you even mentioned anything about it! It shows it’s on the side of the speaker after it’s removed but you cannot tell that the sensor isn’t attached to it, cuz it’s the backside of it!
AND from the looks of your pic… super zoomed in, you can see that u also ripped the flex cable as well…. and even with that mistake being made, you still didn’t mention it or make a red warning note under the pics! Seriously!?
It’s just upsetting cuz now my customer has to wait longer to get her device back.
end rant…:-(
Out pops the perpetrator of that unsightly camera bump.
And yup, that dimple goes all the way down, through the case down to the sapphire crystal lens cover.
Recently, there have been a number of consolidated hardware features in Apple's mobile lineup and this camera is no exception.
It's the same 12 MP, 4K shooter featured in the 6s—a substantial upgrade over the 8 MP 1080p camera we dug up in our last Pro teardown.
On our way to the logic board, we encounter some strange new antenna interconnect boards.
A dab of glue fastens each connector in place, but they come free with a little gentle prying.
The boards themselves serve no obvious purpose; we can only speculate that their flat tops provide a little extra support for the display.
Anyway, time to get a look at that logic board!
Chip chip hooray!
Apple APL1021 A9X 64-bit applications processor
Samsung K3RG1G10BM-KGCH 2 GB (16 Gb) LPDDR4 SDRAM memory
SK Hynix H23QEG8VG1ACR-BC 32 GB (256 Gb) NAND flash memory
2 × Broadcom BCM15900B0 (as seen in the iPad Pro 12.9") touchscreen controller
Apple 339S00109 Wi-Fi module
NXP 66V10 (PN66V) NFC controller and 1610A3 charging IC (as seen in iPhone SE/6s/6s Plus) (CBTL1610A3, possibly a display port multiplexer)
InvenSense EMS-A 6-axis gyroscope and accelerometer combo (also found in iPhone SE)
Notice that the lightning connector in this one is connected via a STRIP, with (plugs?) connecting it to the mother board. Also, it is held in place by SCREWS.
But wait, there's even more chips!
Maxim Integrated MAX98721BEWV boosted class amplifier
M7H YP (likely a Bosch Sensortec BMP280) (BMP282 pressure sensor)
Apple 343S00051-A1 (likely an iteration of the 343S00052-A1 found in the iPad Pro 12.9") power management
Apple 343S00089-A1 power management
STMicroelectronics STM32L052T8 32-Bit ARM Cortex-M0+ microcontroller
Cirrus Logic CS42L83A audio codec
Analog Devices ADAU7002 audio converter
Unfortunately for repair-minded folks like ourselves, the battery contains none of those nifty adhesive pull tabs found in the larger iPad Pro (and in every iPhone since the 5s). So, removing it is a sticky affair.
Maybe next time Apple? Pretty please?
What the battery does contain is a rating of 3.82 V, 27.91 Wh, and 7,306 mAh, amounting to a 10-hour battery life claim.
We're about to leave the case at that, but we try another poke at the Smart connector, hoping for an easier extraction than last time. No such luck.
Texas Instruments SN27545 Battery Fuel Gauge
Personal thinking, the iOpener should be handy in removing the smart connector, since it is glued up.
Well, there is no point of removing the battery, since there is actually nothing beneath.
iPad Pro Repairability Score: 2 out of 10 (10 is easiest to repair)
While not soldered in place, the battery is very solidly adhered—no more pull tabs like we saw in the larger iPad Pro 12.9"
The Smart Connector port is virtually impossible to replace—but incorporates no moving parts and is unlikely to fail.
The LCD and front panel glass are fused together. This slightly simplifies the opening procedure.
The fused front panel increases the cost of screen repair, and the risk of damaging the LCD when opening.
Gobs of adhesive hold everything in place making all repairs more difficult.
43 opmerkingen
No mention of the new integrated Apple SIM?
They tore down the wifi model, so no SIM.
Anyone have a good image of the embedded Apple SIM? I need to know exactly where it is in the iPad Pro 9.7 and 10.5.
joshe -
What about the USB controller, 3.0 or 2.0?
aiple know what to do to get as most money as they can from theyr users and of course they dificult the repair...so there they earn as much as a new one! USER: dont buy aiple, they are fool you...
Typical trolling, Apple has to do things like that in order to make things as thin as possible because they think people want it to get thinner every year.
wmaitner -
Sure they have to do things to make them thinner "because reasons", but the lack of first-party spare parts, pull-tabs or service guides is harder to excuse.
Um how offen is Apple devices Easy to repair?
The 9.7" iPad Pro has USB 2.0, unlike the 12.9" model. Still the display is better, as are the cameras. The A9X is clocked at 2.16 GHz and the RAM is 2 GB. This was probably done because of the smaller battery.
The RAM remained at 2GB only to leave the room for upgrade in the future. Otherwise there will be one less reason for people to sell their 9.7" Pro for a 9.7" Pro 2
Apple A9X supports LPDDR4 and the data bus width is 128 bits. iPad Pro 12.9" is 4GB with two LPDDR4 memory chips. iPad Pro 12.9" uses 128-bits data bus width. iPad Pro 9.7" is 2GB with one LPDDR4 memory chip. iPad Pro 9.7" uses 64-bits data bus width. From system memory perspective, iPad Pro 12.9" has larger system memory density and higher memory bandwidth than iPad Pro 9.7" theoretically.
JJ Wu -
Hey iFixit. Could you please send me all the dimensions for this device (9.7" iPad Pro), the 12.9" iPad Pro and the iPhone 6s screen? I'm am modelling up what might be the most awesome possibility of what the second 12.9" iPad Pro could be.
I purchased the iPad Pro 9.7 128GB model. It is a very nice tablet and runs smoothly and quick. The 2 GB of RAM is not a concern, IOS runs fine on less RAM. Most of the Apple tablets still have 1 GB of RAM and still run fast on the lastest version of IOS. If you purchase Applecare, if the tablet breaks, Apple will just give you a replacement rather than repair for the first two years. Also, Apple products hold their value when it comes time to trade them in on upgrades. I switched from Android to Apple and like Apple better how the iPad links up with the iPhone. I had the Galaxy S5 and the Samsung Pro Tab 8.4, I upgraded to the iPhone 6S Plus in late 2015 and traded in the Samsung Tablet for the Apple iPad Pro 9.7. What I like about Apple, everyone gets software updates at the same time and Apple devices do not slow down like Andriods do. I am not a member of iSheep, I switched from Android to Apple and found Apple better personally.
Where can I find a LCD+Digitzer screen replacement for iPad Pro 9.7? They dont seem to sell them on this site.
Hi stevenvaden, did you manage to source a screen for the iPad Pro 9.7? As I am in need of one myself!! Also do you know if you need to unsolder the original home button to use it on the new Digitizer as is done on the 12.9" version? If this isn't done I believe the Apple Pay system will not work!! (So I have been told)
Mark -
Do you have any information on the location of the magnets?
Thanks, Chris.
As for the audio codec, from http://forums.macrumors.com/threads/ipad...:
"The codec probably belong to CS42L family. You can zoom in the photo and see it's next to the cpu. According to a chinese headphone forum, the latest apple devices share almost the same sound signature."
It seems to be the chip directly above the NXP chip in Step 11.
It is CS42L83A. It is next to NXP NFC chip/SAMSUNG memory chip Step 11.
JJ Wu -
The camera stated to feature the optical image stabilization in the video however, it does not as confirmed by Apple.
"NXP 66V10 NFC Controller and 1610A3 Charging IC (as seen in iPhone SE/6s/6s Plus)"
Is it NFC enabled? Where is NFC antenna?
NFC is exclusively used for Apple Pay. I'm not sure where the NFC antenna is, but I believe it's around the upper right-hand corner of the device.
This model is easier to do a screen replacement than an iPad Air 2, as there is no soldering required, just some careful re-attaching of the home button and front camera bracket..
Where is the Wifi receiver on this model? I have a metal case mounted to the wall that I need to place the unit in, and for our earlier model Ipad we cut a notch where the receiver is to make the wifi reliable. Is it still to the right of the home button, as it was on the IPad 2? Thanks!
Can anyone tell me where the wifi receiver is on this model? Is it the same as the Ipad 2, to the right of the home button? I have a metal case that keeps the ipad from having a good wifi signal unless I cut a notch where the receiver is, and we upgraded to this model from our Ipad 2. Thanks! Jessica
I have an issue with the iPad Pro 9.7 that will charge, but the green indicator will not show that its charging, the battery shows spastic charge amounts, and the Apple pencil does not connect when put in the lighting port. A Macbook will not recognize nor charge the iPad, and I have inspected the ports with a camera; the pins are good and clean. The charger is an iPad charger and the cable is OEM. I have hard reset, and reinstalled. Im thinking the solder points are bad on the lighting port, where its soldered to the logic board, but i’m curious if anyone has had this issue??? I was thinking about reflowing the contacts before trying to solder a new lighting port onto the logic board. Is there a controller that could be bad? I don’t know!!!! Any help would be greatly appreciated.
One time I broke my IPad.
Anyone got any thoughts on screen replacement suppliers? I see a plethora of people advertising screen replacements. How can I find a good quality screen? Some make comments on dead pixels (upto 2 or upto 5) another repairer states to get in contact if you want them to use original parts, but how can you tell a part is original? I’ve seen prices from over $300 down to 100. It has got me feeling like I’m flying blind.
Where are the microphones? Only see one black wire
Is the antenna extension available? sold alongside another or separately (u.FL smd Pcb)
Helped me replace my screen!
I have one with a cracked screen and the microphone doesn’t work. It’s 32gb pro 9.7 used by my 7 and 4 year old. The screen is cracked so poorly and there’s chunks of the tip missing, I can see the back of the camera. Is it worth fixing or should we just junk it and buy a new one?
Bonjour, je cherche la bague qui se trouve en bas autour du connecteur de charge, pourriez vous m’aiguiller SVP ?
I watched a Hugh Jeffreys repair video on one of these iPads today. He recommends not trying to replace housings or smart connectors on this model. Apple's level of greediness recently locking parts to phones and making other parts impossible to remove is going to bite them back one day.
My iPad Pro keeps dropping out turning completely off sometimes every 5to 10 mins suggestions of what is causing this. It is not poor connections nor wi fi low signals can yo help thanku
Denise Dixon - Antwoord
