Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je iPad Air 3 te repareren, gebruik onze reparatiehandleidingen.
  1. iPad Air 3 Teardown, iPad Air 3 Teardown: stap 1, afbeelding 1 van 3 iPad Air 3 Teardown, iPad Air 3 Teardown: stap 1, afbeelding 2 van 3 iPad Air 3 Teardown, iPad Air 3 Teardown: stap 1, afbeelding 3 van 3
    • Before we pop it open and let all the air out, let's check the official hardware specs:
    • 10.5-inch LED-backlit Retina True Tone display with 2224 × 1668 resolution (264 ppi)
    • A12 Bionic SoC with embedded M12 motion coprocessor, Neural Engine, and quad-core GPU
    • 8 MP rear camera + 7 MP FaceTime HD camera
    • 802.11a/b/g/n/ac Wi-Fi with dual band (2.4 GHz and 5 GHz) and MIMO support + Bluetooth 5.0
    • Up to 10 hours battery life
    • 64 or 256 GB of on-board storage
    • Go ahead and switch to X-ray vision ... oh, you can't? Don't worry—we can't either. Luckily, Creative Electron has our back.
  2. iPad Air 3 Teardown: stap 2, afbeelding 1 van 3 iPad Air 3 Teardown: stap 2, afbeelding 2 van 3 iPad Air 3 Teardown: stap 2, afbeelding 3 van 3
    • This new Air hails from the Pro line, inheriting its dimensions, a Smart connector, and a handful of other features from the 2017 10.5" Pro.
    • It does however feature a new model number: A2152.
    • Other differences include: a new, darker Space Gray color, the absence of a camera bump, and two speakers compared to the Pro's four. (Landscape stereo sound is a Pro-only feature.)
    • Compared to its Mini brother, it's pretty much just ... bigger.
  3. iPad Air 3 Teardown: stap 3, afbeelding 1 van 3 iPad Air 3 Teardown: stap 3, afbeelding 2 van 3 iPad Air 3 Teardown: stap 3, afbeelding 3 van 3
    • iPads continue to be tough nuts to crack, so we raise the stakes—or rather, the iOpeners.
    • Since the log cabin method works so well for building fires, maybe it'll help our iOpeners heat up this iPad.
    • With their powers combined, plus some suction and slicing, we get into this fused display and start to lever it open.
    • Our first peek inside reveals an internal layout that's rather different from Airs past, featuring a central logic board—as seen in certain Pro iPads.
  4. iPad Air 3 Teardown: stap 4, afbeelding 1 van 3 iPad Air 3 Teardown: stap 4, afbeelding 2 van 3 iPad Air 3 Teardown: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Battery Blocker
    $3.99
    Koop
    • Safety first! This battery disconnection is definitely not as foolproof as the bracket in the iPad Mini 5.
    • To protect yourself and your device, the battery should be disconnected as soon as possible. In this case, the connector is trapped under the logic board, so it needs a little help from a friend.
    • It feels like the display cables are just too short to easily free the cable bracket, making for a thrilling balancing/unscrewing act.
    • The dual-celled 30.8 Wh battery is a little bigger than the 30.2 Wh Apple promised, taking after the 10.5" Pro, and a big upgrade from the 27.6 Wh battery in the Air 2.
    • If only it had also inherited the highly-coveted stretch-release adhesive pull tabs ... sigh.
  5. iPad Air 3 Teardown: stap 5, afbeelding 1 van 2 iPad Air 3 Teardown: stap 5, afbeelding 2 van 2
    • With the 10.5-ification of this Air, the updated display gets Apple Pencil support—but only second-class, leaving the new Pencil 2 exclusively to the Pro line.
    • We also spot some extra adhesive near the top of the screen—aww, Apple you shouldn't have. No, seriously.
    • Responsible for turning your finger pokes into ones and zeroes, we have:
    • Likely Renesas (formerly Intersil) ISL24882B 8-Ch. TFT-LCD reference voltage generator w/ integrated EEPROM (seen in the 10.5" Pro)
    • Parade Technologies DP825 timing controller (previously seen in the 10.5" Pro)
    • Texas Instruments TPS65195 level shifter (seen in the Mini 5)
    • The size is similar, the Pencil support is similar, and the chips are similar to the 10.5" Pro. However, the Air is missing one notable Pro feature—the cool ProMotion 120 Hz display.
    I guess it’s the Intersil in red that’s causing all the heat while using the Apple Pencil. Gets nice and warm in that bottom corner while taking notes etc.
    joshuacurd - Antwoord
    Will iPad Pro 10.5” display fit and work on iPad Air 3?
    mail2augus87 - Antwoord
  6. iPad Air 3 Teardown: stap 6, afbeelding 1 van 3 iPad Air 3 Teardown: stap 6, afbeelding 2 van 3 iPad Air 3 Teardown: stap 6, afbeelding 3 van 3
    • In place of the 10.5" Pro's surround sound speakers, we find a large metal bracket and two posts built into the case.
    • These little metal mesas likely support the display and hold additional antennas in the LTE models.
    • While the Mini's front-facing camera got a significant upgrade, the Air's rear camera holds steady at 8 MP—meaning the Pro's 12 MP still reigns supreme in the 10.5" tablet photo arena.
    • We do away with a single screw and peel back a huge shield from the logic board, exposing that sweet silicon underneath.
    • The single screw here is a tenth of the fastening power we saw on the 10.5" Pro's logic board shield.
  7. iPad Air 3 Teardown: stap 7, afbeelding 1 van 3 iPad Air 3 Teardown: stap 7, afbeelding 2 van 3 iPad Air 3 Teardown: stap 7, afbeelding 3 van 3
    • Shields dispatched, we've got some air-fried chips for you!
    • Apple APL1W81 A12 Bionic SoC layered over 3 GB SK Hynix H9HKNNNDBMMUYR LPDDR4X RAM
    • Toshiba TSB3243V40755TWNA1 64 GB NAND flash
    • Apple 343S00281-A0 Power Management
    • Apple/Universal Scientific Industrial USI 339S00551 Wi-Fi/Bluetooth Module (as seen in the iPhone XS)
    • 2x Broadcom BCM15900B0 touch screen controllers
    • Apple 343S00264-A0 power management IC
    • NXP Semiconductor SN100V NFC controller (likely)
    what is that LIFD6 chip just above the processor?
    Ralph Hipps - Antwoord
  8. iPad Air 3 Teardown: stap 8, afbeelding 1 van 3 iPad Air 3 Teardown: stap 8, afbeelding 2 van 3 iPad Air 3 Teardown: stap 8, afbeelding 3 van 3
    • IC identification, continued:
    • NXP Semiconductor CBTL1612A1 Display Port multiplexer
    • Cypress Semiconductor CYPD2104 USB-C port controller
    • Cirrus Logic CS42L83A audio codec
    • Cirrus Logic audio amplifier
    • Bosch Sensortec accelerometer/gyroscope
    • Bosch Sensortec pressure sensor
  9. iPad Air 3 Teardown: stap 9, afbeelding 1 van 1
    • Not to sound like a broken record, but your eyes don't deceive you! That Air 3 looks an awful lot like the 10.5" Pro!
    • A central logic board, dual-cell battery, Apple Pencil support, and Smart connector all say "Pro" to us—we're just missing the second set of speakers!
    • The Air 2 and the 10.5" Pro both have pretty miserable repairability scores. Could this tablet break the mold? Scroll down to find out!
    • And in case you missed it, there was a whole other iPad released only recently. Take a peek at the iPad Mini 5 teardown here!
    The iPad Air 3 is not out yet
    Phufaa S - Antwoord
  10. Laatste gedachten
    • A single Phillips driver takes care of all the screws.
    • Many components are modular and can be replaced independently, but the Lightning port is soldered to the logic board.
    • Battery replacement is possible, but still unnecessarily difficult.
    • Gobs of adhesive hold many parts and cables in place, complicating all repairs.
    Repareerbaarheidsscore
    2
    Repareerbaarheid 2 op 10
    (10 is gemakkelijkst te repareren)
Adam O'Camb
196.170 Reputatie
416 handleidingen geschreven
26 opmerkingen
Screen compatibility?
Ryan Galvan - Antwoord
I am also curious about this
Larry_Xia -
Can I ask? Lightning port uses USB2 or USB3 speed?
Pavel Syky - Antwoord
usb 3. see here it uses same 16 pins lightning port as pro 10.5 :D https://www.mobilesentrix.com/charging-p...
echow2001 -
Well never mind. iPad came in and has usb2
echow2001 -
what parts are interchangeable from the iPad pro 10.5 and the iPad Air 3 ? Screen, Battery, Chargerport ?
iPhone 3GS KING - Antwoord
Double-sided Lightning port? (I’m giving up on Lightning; I now believe Apple has made the decision to not pursue Lightning as a long-term connector format, so I’d be surprised to see double-sided here (which could be nearly-as-capable as USB Type-C, pin-wise, minus the legacy USB2 channel).)
And, in your expert opinion, how difficult do you folks think it would have been for Apple to have architected this chassis (and the iPad mini 5 chassis) to support the use of both laminated AND non-laminated displays? I would greatly like Apple, at some point, to show that they’re designing simultaneously for the needs of education/low-cost buyers and “$500 tablet” buyers, differentiating by screen quality and repair cost. The iPad mini 5 chassis -looks- like it could fit the mini 3 non-laminated display within it, if the proper standoffs were milled in (weren’t milled out). IMHO, seeing that kind of “long term vision” of chassis reuse would be a good sign. (I hold out hope of seeing the iPad mini 5th gen mobo in the iPad 7th gen.)
Scott - Antwoord
yes the port is double side. seems the usb3 controller is integrate into the SOC this time around.
echow2001 -
I think Air 3 is nothing but a budget replica of the 10.5” Pro.
Gorilla - Antwoord
Another difference - my 10.5” pro has 4gb of ram vs 3gb in the air 3.
garyelevin - Antwoord
The screen connections look identical to pro 10.5”, are they interchangeable?
mattyG Piano fingers - Antwoord
I broke my ipad air 3 screen. Can use the ipad pro 10.5 screen on the ipad air? Just the screen not the lcd.
Rob Malloy - Antwoord
Good evening could the nand Flash memory be upgradable like to 512gb?
jorge puentes - Antwoord
Hi Jorge,
As the memory is basically chips on the logic board, it is not possible to upgrade it. You can try to replace the entire logic board with one that has a higher capacity pre-installed.
Arthur Shi -
does it have a digitizer
Jaidul Islam - Antwoord
Phufaa S - Antwoord
The screen from the iPad Pro 10.5 does not work on the iPad Air 3. I’ve tried.
Abdullah - Antwoord
Anyone aware of the multiple issues with Apple Pencil ( 1st. Generation) connecting with the iPad Air? I’m on my second brand new one in 2 weeks and unable to use the pencil. It will not even register/pair with the air. Software updated, fully charged both iPad and pencil. Tried my daughters pencil and it wouldn’t connect/ pair with either of the airs. Both my pencil and my daughters work perfectly with a 12.9 “ iPad Pro and a 9.7 “ iPad Pro without issues. Any response would be helpful. I’m going to ask Apple for a complete refund…
Steve. Adrian - Antwoord
I’ve found that I have a pressure point (white spot in the screen) and I’ve used multiple methods to remove it, with no success. Places like ubreakifix wanted $250 to just replace the screen, and it’s past warranty to try and take it to Apple to replace.
Russell - Antwoord
Russell, that pressure point was a known issue of the 10.5” iPad Pros that this iPad Air is based on, it’s a shame Apple didn’t fix it with this update. Some people have had luck getting a replacement from Apple even out of warranty since it’s a manufacturer defect. If that doesn’t work, you can pay Apple for a battery replacement (usually $99) and they’ll give you a new (refurbished) device since their techs don’t do iPad battery swaps! Not a perfect solution, but I hope this helps. I had the same thing happen to my iPad Pro.
Taylor Dixon -
Great video, pics and guide. I will definitely not be opening up my iPad Air 3 to fix it. I shall leave it to the experts like you!
Dave - Antwoord
is the lightning port part on the iPad Air 3 the same as on the iPad Pro 10.5?
Joe Lamb - Antwoord
Anyone else knows if the white spot issue has a tendency to get worst overtime? Someone on the apple forum noticed it happens near the are of the logic board where some conector are placed, raising the possibility of a heated related damage to the screen. Since the size of the logic board is limited (as well as the size of such connectors) will the problem get worst over time?
Thiago Izoton - Antwoord
Do you have a kit for replacing the main screen on an iPad Air 3? If so, do you have a walk through showing how to change said screen.
William Watson - Antwoord
Yes, that's here: iPad Air 3 Vervanging van het scherm. You'll find the links to the parts you need on the top right of the guide :-)
Sandra Hiller -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 98
Afgelopen 30 dagen: 447
Altijd: 94,920
