Inleiding
In the calm after the iPhone 5s/c storm, Apple thought it could slip a couple new iMacs by us. Time for us to get our pry on and pop this next generation 27" iMac wide open for a quick tour of the highlights.
We also tore apart the newly refreshed smaller-brother iMac 21.5"—head over to its teardown and check it out too.
Can't get enough of our play-by-play? Show us your game face on Twitter, Instagram, or Facebook.
Wat je nodig hebt
Externally, the iMac Intel 27" EMC 2639 looks identical to the previous generation, but the interior specs have been upgraded:
3.2GHz quad-core Intel Core i5 processor (Turbo Boost up to 3.6GHz) with 6MB L3 cache
NVIDIA GeForce GT 755M graphics processor with 1GB of GDDR5 memory
802.11ac Wi-Fi
PCIe flash SSD available
Gereedschap gebruikt in deze stap:iMac Opening Wheel$7.99
After some quick slicing with our handy iMac Opening Tool, we pop the hood and get a massive bout of deja vu.
The AirPort/Bluetooth card, conforming to the 802.11ac Wi-Fi standard, still clings to the back of the logic board — making replacement no easier than before.
Not the first Mac to get updated with the new ac standard, we expected to see some similar hardware as in the refreshed MacBook Airs from earlier this year.
Chips off the
oldnew block: -
Broadcom BCM4360KML1G 5G WiFi 3-Stream 802.11ac Gigabit Transceiver—as expected, this is the same chip driving the ac Wi-Fi in the 11" and 13" MacBook Air
Skyworks SE5516 Dual-Band 802.11a/b/g/n/ac WLAN Front-End Module
Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI Solution with Bluetooth Low Energy (BLE) Support
Replaceable Wifi card is excellent news. Question: is it possible to upgrade the WiFi card to 'ac' in previous Late 2012 iMac? If so, where can I buy that part?
As is now standard across all new iMacs, the new iMac 27" features support for PCIe-based flash storage. This is a pleasant surprise compared to last year's 21.5" model, when we were left sorely disappointed by unpopulated solder pads on our low-end logic board.
According to Apple, the inclusion of PCIe flash storage allows for up to 50 percent faster speeds than the previous generation.
i jst want to know if i can upgrade my graphics card to NVIDIA GeForce GTX 780M with 4 g.b memory,, is i ?!
Thankfully, its 27" big brother was saved from the same fate, and power users will still be able to upgrade their processor without a reflow oven.
I've never heard of anyone buying a Mac expecting to upgrade the CPU (or ever having to replace one).
Not to mention that the reason the CPU is soldered in the 21.5" iMac is because it's the only formfactor Intel sells the CPU in with the Iris Pro graphics. You CANNOT get that chip with a socket. No way, no how.
Given this iMac does not need the Intel graphics, Apple went with the traditional socketed design.
Blame Intel for that one, not Apple.
(Though I agree - do people really upgrade their CPUs? Short of enthusiasts who upgrade every 6 months (who would never buy an iMac anyways...), by the time one finds the CPU too slow, it's time to upgrade the entire machine anyhow. Even on a PC you'd probably have to replace the motherboard, so soldered or not...).
Do we know which i7 they're using in the 27"?
This one it seems: http://www.cpu-world.com/CPUs/Core_i7/In...
1derer -
I've done it before. If you're happy with the shell it's a great way to spend 10% of a computer's replacement cost and still enjoy a generational leap forward in performance. Made my G4 last 10 years that way through RAM, Graphics Card and Processor upgrades. This is the same thing. I bought a Haswell iMac 27 only because the screen is so much better than my iMac 24. Otherwise I would have figured out a way to stretch my $2400 investment from 2008. Did the same with a Macintosh Plus too. Well a 2 Mb upgrade and cutting the 256k resister. Still. I've always enjoyed messing with out of the box items.
Heavy-weight ICs:
Intel platform controller hub
As advertised, the iMac 27" now sports a fancy new graphics processor:
NVIDIA GeForce GT 755M GPU
Four SK hynix H5GQ2H24AFR 256 MB GDDR5 SGRAM ICs make up the 1 GB of graphics RAM
Good day!
Is there any information about which exactly north bridge is installed on this model (ref to: Intel platform controller hub)?
Today I got my iMac 1419 from non-official service and noticeably work slower and image update very slow on the screen compared to late 2011 iMac sending next to this one.
Hola Tocayo, excelente explicación pero me podrìas orientar de como quitar el CPU, lo quiero actualizar a un core i7, gracias
The B-side of our IC record:
NXP ARM7TDMI-S based Microcontroller
Analog Devices SSM3302 audio amplifier
Cirrus Logic 4206BCNZ audio controller, the same chip as found in last year's 21.5"
Vimicro VC0359 webcam processor
Broadcom BCM57765A1KMLG gigabit ethernet controller with integrated SDXC card reader
Intel DSL3510L Cactus Ridge Thunderbolt controller
iMac 27" EMC 2639 Repairability Score: 5 out of 10 (10 is easiest to repair)
RAM is user-replaceable without opening the case, thanks to the rear access door.
You can still replace the hard drive and CPU inside this machine, albeit with some adhesive cutting.
Components are modular and fairly easy to remove.
Budget-minded folks now can add a second hard drive to the base iMac because the Fusion Drive connector is no longer missing from the logic board.
The glass and LCD are fused together, and there are no more magnets holding the glass in place.
You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
22 opmerkingen
You forget to mention *HOW* one should mount an extra SSD in the new port.
Do we need to remove the LCD panel or is there a slot you can access through the back, like with RAM?
You'll need to remove the LCD and dig your way inside.
On the BTO "SSD flash memory only model", is the SSD connected to the rear PCIe port leaving an empty SATA port? So someone could add an additional SATA drive?
Thx
I am also looking for the same info. Anybody has an ans?
imacsps -
Thanks for the tear-down...very nice as usual.
I'm glad we can still easily upgrade RAM on the 27" iMac. I would still like to be able to easily upgrade the HDD and/or SSD though - especially as SSDs get cheaper.
What we be required to install a second drive? I would like to keep the stock 1tb hdd and add a Samsung S30 SSD.
Has discover how to add a second drive? thanks
1) In order to "upgrade" the CPU, would you just "pop out" the current i5/i7 and plop a new one in? Are some not going to work? Would you need to do any software upgrades, etc.?
2) Same sort of question regarding the fusion drive slot. Would this only work with an apple fusion flash drive? could you just plop in a samsung, etc SSD? Any max for storage space?
There is no "popping out or plopping in" a replacement processor in this or any other iMac, save for some of the earliest G3 and G4 machines. If you're going to upgrade your processor then plan on replacing the mother board complete, and then only the particular board that fit into the same model machine. This is the only way an upgrade can be achieved without a lot of 'board level' experience, the sort that won't be addressed here. Popping and plopping is saved only for various PC variants but then we don't see much in the way of generic and mundane in the Mac world.
Ok just tore mine down thinking I could easily add a SSD drive to my 1TB sata setup. NOT. There is NO additional SATA port and the one that's on the MOBO is proprietary to Apple. So unless you have a converter that can adapt a STANDARD sata cable and power, then adding your own "Fusion Drive" setup is not going to happen. However, if you bought the SSD model then you can add the additional HDD but would still need to split power from their proprietary power cable. UGH.
Is the GPU upgradeable? Can I swap a GeForce GTX 780m for the base 755m card?
Does the fusion drive have a PCIe SSD and a standard sata HD or is it a special drive? Can it be splitted into two individual drives again?
Eric Haulenbeek.... I just hate it when people spout off things as if they were gospel when they have no friggin' idea what they're talking about. Case in point: your assertion that you can't upgrade the CPU in these Macs without board level tweaking. Utter nonsense! Pick a CPU that will fit the same socket and TDP and you're in business. To be safe, you should pick a CPU that Apple has already installed in the same model so that the firmware will support it. For example, you could replace the 3.2GHz Core i5 4570 with the 3.5GHz Core i7 4771. Whether this would be an economically wise course of action is another question.
I have a mid 2010 iMac 27, containing internally a 2TB conventional hard drive, and 240Gig SSD drive replacing the DVD drive. I’ve been offered an iMac 27 late 2013. Is there merit in swapping into it the 2TB and SSD drives from my 2010 model. Is there room and connectors to make this possible? Thoughts of others?
Regards,
Terry
It’s been a year since you wrote this… great time to use a Big Sur hack… the 2013 I just acquired doesn’t have a SATA port installed. But Amazon and eBay had one. Pull the logic board and hook it up. Then enjoy the extra data connection. Nvme to apple SSD adapter works with no sleep wake issues.
Did a CPU swap to a Xeon 1231 v3… thus far it will not POST or turn on. It leads me to believe/hope I didn’t connect the power supply well. I’m a little exhausted this was a rigorous job, tomorrow is another day. Insights welcome until then.
Got back in, bent some CPU pins…. daintily put them back. Go for boot. Recommendation remove the plastic ram cage and start reattaching the CPU from the side closest to the edge. I can’t confirm the Xeon didn’t work, I didn’t see a point in testing too variables for repair and another surgery afterwards.
Rather than change parts and replace thermal paste to the heatsink and CPU, can I buy a new logic board?
great job!! thankx alot but i want to know if i can upgrade my vcar to NVIDIA GeForce GTX 780M 4 gigs memory mine is 2 gigs any advice or how to do it plz?!
gforceemas - Antwoord
Hi, Do you now if is possible change the thunderbolt port? for this mac
27-inch, Late 2012 (Model A1419)
Procesador 3,4 GHz Intel Core i7
Memoria 16 GB 1600 MHz DDR3
Gráficos NVIDIA GeForce GTX 675MX 1024 MB
Número de serie D25L71B2DNMP
Software OS X 10.8.5 (12F37)
Model A1419
Cesar - Antwoord
