full teardown of the laptop you also will see how you have to replace stuff.
Deze demontage is geen reparatiehandleiding. Om je Hp Pavilion dv9363ea te repareren, gebruik onze reparatiehandleidingen .
first of all, if you start to work on your laptop make a plane of the screws. Use an magnetic project board. or just paper and tape and draw the plan.
remove the battery, and the 3 panels.
now we will remove the dvd rw drive.
first remove the screw at the back of the laptop (bottom) see first picture
than use a spudger to slide the dvd drive away of the laptop.
in this step we will remove the keyboard.
there are 10 screws to remove in total. 1 screw on the botoom plate , 6 screws in the battery compartment and 3 under the grey plastic board above the keyboard.
first remove the black screw on the bottom , it's next to the screw of the dvd drive.
than remove the 6 grey little screws of the battery compartment.
then remove the grey plastic board above the keyboard. see picture 3, to be continued in the next step
if you remove the grey plastic board be carefull for the wire and socket
than remove the other screws from the keyboard. see picture 2
now you can remove the keyboard.
remove the rest of the screws of the bottom plate.
like i said before, make a plan of the screws and parts. it's easier to put it back together
now remove all the other screws on the upper case. (under the keyboard)
also remove the cables/wires.
the power board is in the left upper corner. be carefull with the sockets.
some wires are taped or glued so be carefull.
if every screw and wire is loose then you are ready to remove the grey plastic board (arround the keyboard)
slide the spudger arround the case. it's very easy to remove. just hear the clicks.
after removing this plastic frame , the main board is visible.
now we will remove the power PCB
first remove the connectors but be carefull they are very breakable. and remove the screw, than remove the PCB
then remove the red circled screw
the yellow and 3 blue screws are from the screen henges.
remove usb boards and sd card reader.
the yellow circkled PCB below is the Bluetooth PCB. watch out for the connector.
the blue circkled connector is the connector of the sd card reader PCB; be carefull if you remove.
before we go further with the PCB's , we will remove the screen.
remove the screws of the henges at the 2 sides.
be carefull with the connectors. i broke the connector of the webcam PCB.
remove the DC jack and usb PCB.
again be carefull with the connectors.
arround the dc jack is a metal frame. remove it before you remove the PCB
in this step we will begin at the main board or motherboard..
we will remove the fan and cpu cooler.
the cpu koeler is in 2 pieces. 1 for the cpu and another chip. than a fan for the Nvidia chip.
remove and clean the pcu fan. in this laptop was a lot of cat hear, that caused a blocked fan.
also put new cpu cooling paste on the chips. ( and processor)
now the lcd screen...
i don't have to tell you that you have to be careful...
remove the black dots ( the screws are under the black dots)
if you removed all the screws than use the spudger or isesamo to open the frame. you will hear the clicks..
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Enkele stap
Volledige handleiding
Klein - 600px
Middelgroot - 800px
Groot - 1200px
Voorbeeld
