Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 10 —
Stap type:
Sleep om te herschikken
Microsoft Surface Pro 5 Repairability Score: 1 out of 10 (10 is easiest to repair)
Although we like connectors, the ones present in the Surface Pro aren't standard, making display removal tricky.
The display removal procedure is simplified by the use of thin foam adhesive and a fused display, but is still not trivial.
Adhesive holds many components in place, including the display and battery.
Replacement of any part requires removal of the display assembly, an easy part to damage.
The SSD is no longer replaceable.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
