Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 7 —
Stap type:
Sleep om te herschikken
Careful! If you don't remove the feet and the screws underneath before you try to pull off the front panel, the tab can split!
Once all screws are removed, you should be able to pull off the front drive panel.
The wire connecting the front panel (green squares in the third image) can be pulled out gently by hand or with the help of a spudger.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
