Ga door naar hoofdinhoud
Nokia 1208 Mobile Phone Teardown
Engels
Nederlands
Stap 2
Nokia 1208 Mobile Phone Teardown, Removing battery and SIM card: stap 0, afbeelding 1 van 3 Nokia 1208 Mobile Phone Teardown, Removing battery and SIM card: stap 0, afbeelding 2 van 3 Nokia 1208 Mobile Phone Teardown, Removing battery and SIM card: stap 0, afbeelding 3 van 3
  • FIRST, MAKE SHURE YOU SHUT THE PHONE DOWN! You can take the back cover off by sliding the cover away from the top side, if the LED light is facing you, slide the cover away from you, then just lift the battery out
  • If the battery is out, lift the litle metal piece UP to remove the sim card. Be carefull not to break anything of the phone.
  • Let's go to the next step.
Vertaling hier toevoegen
