Ga door naar hoofdinhoud
Amazon Echo Dot Teardown
Engels
Nederlands
Stap 7
Amazon Echo Dot Teardown: stap 0, afbeelding 1 van 2 Amazon Echo Dot Teardown: stap 0, afbeelding 2 van 2
  • With the screws removed, only a thin ribbon cable ties all these layers together. Introducing Amazon Echo Dot: Accordion Edition.
  • At one end lies the motherboard and ports, while a separate board at the other end hosts the volume controls and microphone array. A single cable threads its way through the intervening layers to connect the two boards.
  • We shuffle the layers of plastic and silicon back together temporarily; it's all coming apart soon enough.
  • After tweezing away the ribbon cable, we're ready to inspect the motherboard.
Vertaling hier toevoegen
