Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Bewerken van stap 7 —
Stap type:
Sleep om te herschikken
In the next few steps, we remove many components that are very similar to the last 21.5" iMac.
The WD Caviar Blue hard drive is held to the front bezel by a few screws and, as always, the SATA data/power connectors.
The WD Caviar Blue drive is a non-standard SATA drive. The power connector features 7 pins, rather than the standard 4. The drive also has non-standard firmware. This means you can only use Apple's own hard drives and not any standard after-market SATA drive.
Removing the power supply requires disconnecting the AC inlet cable from the logic board.
The LED driver board comes out next after successfully removing the power supply.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
