Ga door naar hoofdinhoud
Magic Trackpad 2 Teardown
Engels
Nederlands
Stap 10
Magic Trackpad 2 Teardown: stap 0, afbeelding 1 van 3 Magic Trackpad 2 Teardown: stap 0, afbeelding 2 van 3 Magic Trackpad 2 Teardown: stap 0, afbeelding 3 van 3
  • A single, elegant chip resides on the touchpad.
  • Broadcom BCM5976 Touch Controller (part of the same series of Broadcom touch controller chips used in many Apple devices)
  • The strain gauges, mounted on each of the four spring tabs, are used to measure the force applied to the trackpad surface.
  • As you press down on the trackpad, the springs deflect, stretching the strain gauges and increasing their resistance. A microcontroller measures that resistance and determines the appropriate level of haptic Taptic feedback to deliver.
Vertaling hier toevoegen
