Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 8 —
Stap type:
Sleep om te herschikken
With the back half of the display assembly dispatched, we set to work removing the display from the front glass.
This particular machine uses a vacuum to secure the iPhone's glass to a heated surface. This process helps to weaken the optically clear adhesive (OCA) that secures the glass to the actual display.
Once the OCA had been sapped of its sticky strength, a .08 mm molybdenum wire makes short work of fully separating the LCD from the glass panel.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
