Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Help
Bewerken van stap 3 —
Stap type:
Sleep om te herschikken
Remove the 6 long medium screws
Remove the medium medium screw. This screw is conveniently marked with an S if you forget what goes where.
The blueray drive is NOT screwed down. Do not tip the console!
Use a finger to press the tab next to the medium length screw and lift. The case pivots on the front.
When putting back together, place the front edge and rotate back. The screws will pop everything back in place.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
