Ga door naar hoofdinhoud
Finelife NV-023172 2 Slice Toaster Teardown
Engels
Nederlands
Stap 6
Finelife NV-023172 2 Slice Toaster Teardown, Latch Mechanism and Strain Relief: stap 0, afbeelding 1 van 3 Finelife NV-023172 2 Slice Toaster Teardown, Latch Mechanism and Strain Relief: stap 0, afbeelding 2 van 3 Finelife NV-023172 2 Slice Toaster Teardown, Latch Mechanism and Strain Relief: stap 0, afbeelding 3 van 3
  • The latch mechanism contains:
  • A ferromagnetic piece that the electromagnet holds
  • An arm to close the power switch
  • A spring to launch toast in a vertical direction
  • Note: The latch mechanism can be removed by further bending the sheet metal. This is not advised as it may be very difficult to bend the sheet metal back to its original position during reassembly.
  • Pieces of electrical insulation board hold the wires. The heating elements are directly riveted to the boards and the boards are riveted to the sheet metal frame.
  • The strain relief can be removed by undoing 2 screws (blue). The screws have a special head type. They can be gripped with small needle nose pliers or wire cutters.
  • The strain relief cover comes straight off once the screws are removed
Vertaling hier toevoegen
