Ga door naar hoofdinhoud
Finelife NV-023172 2 Slice Toaster Teardown
Engels
Nederlands
Stap 4
Finelife NV-023172 2 Slice Toaster Teardown, Full Case Removal: stap 0, afbeelding 1 van 1
Full Case Removal
  • One at a time, slide the metal side panels upwards and remove them from the toaster. The bottom flanges must be slightly bent outward to clear the toaster internals.
  • If the panels do not remove cleanly, double check that the tabs mentioned in Step 3 are clear of the other sheet metal parts in the toaster.
Vertaling hier toevoegen
