Ga door naar hoofdinhoud
Epson Stylus Printhead Teardown
Engels
Nederlands
Stap 13
Epson Stylus Printhead Teardown: stap 0, afbeelding 1 van 3 Epson Stylus Printhead Teardown: stap 0, afbeelding 2 van 3 Epson Stylus Printhead Teardown: stap 0, afbeelding 3 van 3
  • Let's answer your last question about the printhead now: How does it print?
  • The action starts in the second picture.
  • The ink inlet fills the chamber with ink (yellow).
  • The ink is prevented from exiting the nozzle by surface tension.
  • (Third image) When the printer needs to print, electrical current is applied to the piezo element which expands, creates pressure, and forces a single drop of ink out of the nozzle.
  • The (microscopic) drop of ink falls on the paper.
  • The contraction of the piezo element causes the remaining ink in the nozzle opening to be sucked back into the chamber.
  • Keep in mind that this printer has to control over 240 piezo elements which move over the paper many times in the time it takes to print a single page.
Vertaling hier toevoegen
