Ga door naar hoofdinhoud
Samsung Galaxy S5 Mini Teardown
Engels
Nederlands
Stap 18 vertalen
Stap 18
Samsung Galaxy S5 Mini Teardown: stap 0, afbeelding 1 van 2 Samsung Galaxy S5 Mini Teardown: stap 0, afbeelding 2 van 2
  • Samsung Galaxy S5 Mini Repairability Score: 5 out of 10 (10 is easiest to repair).
  • The battery is incredibly easy to remove and replace.
  • The display is now one of the first components out, making its replacement a little faster. However, it is held in with a significant amount of adhesive and requires very careful and persistent prying, as well as a considerable amount of heat to remove without cracking the glass or cutting cables.
  • Once you get the device open, several components are modular and fairly easy to replace, such as the cameras, headphone jack, vibrator motor, and speakers.
  • Replacing anything other than the battery requires first removing the display, risking extra damage on the way to a repair.
Vertaling hier toevoegen
