Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Bewerken van stap 22 —
Stap type:
Sleep om te herschikken
The digitizer ribbon cable is extremely delicate. We're not joking on this. It's about the thickness of a human hair. Proceed with caution.
Use the edge of a plastic opening tool to carefully lift the digitizer ribbon cable off the two positioning pegs on the inner case.
Remove the following screws securing the inner case to the front case:
Four 6.3 mm Phillips
Two 3 mm Phillips
Pull the same retaining tab used to secure the logic board away from the center of the Newton to release the inner case, then pull it away from the bottom of the Newton and set it aside.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
