Ga door naar hoofdinhoud
Help
Bewerken van stap 17 —
Stap type:
Sleep om te herschikken
Macintosh 128K Repairability Score 7 out of 10 (10 is easiest to repair).
Once you’re inside, it’s simple and straightforward to replace any of the main components: floppy drive, power supply, logic board, or CRT display.
No adhesive anywhere.
User-replaceable clock battery.
Limited upgradability: The RAM is soldered to the logic board and can’t be replaced, and there’s no slot/port to add an internal drive. However, you can expand storage via an optional external floppy drive.
The case is fairly difficult to open, with deeply recessed screws and a tight panel fit.
There are some dangerous high voltages on both the power supply and the CRT that make repair potentially hazardous.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
