Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 11 —
Stap type:
Sleep om te herschikken
Remove the four silver Phillips screws attaching the logic board to the outer case.
To remove the logic board, you must first de-solder the leads of both microphones from the logic board. When soldering on a circuit board, be sure not to heat up the connection excessively.
Use a pair of tweezers to gently pull each lead as you heat up the joint with the tip of a soldering iron.
Repeat this process to remove all four microphone leads. Their locations are boxed in orange on the first picture.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
