Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 12 —
Stap type:
Sleep om te herschikken
Remove these phillips screws:
To remove all 6, you will need to slide the sliding assembly to get to the center two screws.
Now, using a spudger, or flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
This may take a little force since a mild adhesive is applied around the rim.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
