Ga door naar hoofdinhoud
ANDIS CEC-100 Teardown
Engels
Nederlands
Stap 4
ANDIS CEC-100 Teardown, The Fix: stap 0, afbeelding 1 van 2 ANDIS CEC-100 Teardown, The Fix: stap 0, afbeelding 2 van 2
The Fix
  • What you will need to repair. Soldering Iron, paste flux and solder.
  • Next you will want to heat up your solder station and apply some flux to both the wire and the connector pin. I prefer to use Amtech flux however any flux is better then no flux.
  • Find a comfortable position that limits the amount of movement of both the wire and then switch.
  • Solder the wire to the pin.
Vertaling hier toevoegen
