Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Help
Bewerken van stap 2 —
Stap type:
Sleep om te herschikken
First use a thin metal spudger to remove the four self-adhesive plastic dots covering the screw holes.
Remove the four Phillips screws holding the cases together. You'll need a thin-shafted screwdriver to remove them.
Ventilation holes abound in the top and rear outer cases. Such a Swiss cheese case design allows the chumby to cool off without the need for a fan.
There are no screws in the bottom case; it is held in place when the cases are fastened together.
Pull the rear case away from the chumby to reveal the spiffy internals.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
