Ga door naar hoofdinhoud
Breville Toaster Teardown
Engels
Nederlands
Stap 3
Breville Toaster Teardown: stap 0, afbeelding 1 van 3 Breville Toaster Teardown: stap 0, afbeelding 2 van 3 Breville Toaster Teardown: stap 0, afbeelding 3 van 3
  • Once removing the screws, partially seperate the body from the white casing.
  • As shown, there are 4 screws that have to be removed to fully seperate the 2 parts.
  • Use a phillips screwdriver to unscrew the screws.
  • Flip the toaster on the other side and pull the highlighted wire to detach it from the bottom part.
  • You can now seperate the parts to give 2 seperate parts. (The white casing and the electrical body).
Vertaling hier toevoegen
