Ga door naar hoofdinhoud
Breville Toaster Teardown
Engels
Nederlands
Stap 16 vertalen
Stap 16
Breville Toaster Teardown: stap 0, afbeelding 1 van 2 Breville Toaster Teardown: stap 0, afbeelding 2 van 2
  • Now that the latch is open you can remove the final wire attached to the plastic part. This concludes the teardown of removable parts within the toaster.
  • Note: Removing other remaining parts may alter the function of the toaster as they are permanently joined.
  • You have now completed the teardown.
Vertaling hier toevoegen
