Stap 13 vertalen
Stap 13
Final Thoughts
The Motorola Razr earns a 1 out of 10 on our repairability scale (10 is easiest to repair):
The only driver you'll need is a standard T3 Torx.
The delicate primary display is replaceable, if you're determined.
Every repair starts (and ends) with stubborn, glued-on outer covers.
Replacing the battery—or rather, batteries—requires near-total disassembly.
The charging port is soldered directly to the main board.
Complex construction and multiple flex cable booby traps makes for tricky repair work.
