Ga door naar hoofdinhoud
iPad 7 Teardown
Engels
Nederlands
Stap 9 vertalen
Stap 9
iPad 7 Teardown, Final Thoughts: stap 0, afbeelding 1 van 1
Final Thoughts
  • The 7th-Generation iPad earns a 2 out of 10 on our repairability scale (10 is the easiest to repair):
  • Non-laminated, separately replaceable cover glass and LCD makes most screen repairs far less expensive.
  • The LCD is simple to remove once you separate the cover glass/digitizer.
  • As with all iPads, a solid barrier of very strong adhesive hinders all repairs.
  • The Lightning port, a common point of failure, is soldered to the logic board.
  • More adhesive holds nearly everything else in place. Battery and logic board replacements are particularly obnoxious.
Vertaling hier toevoegen
