Ga door naar hoofdinhoud
Help
Bewerken van stap 1 —
Stap type:
Sleep om te herschikken
Before disassembling the camera, we'll need to remove the battery and memory card.
Turn the camera over and gently push the battery door toward the side.
The door is spring-loaded and will flip up.
Once the door is open, press the battery release and the battery will eject. The battery will then slide out easily.
If there is a Memory Stick installed, press it gently and it will eject from the slot.
When the battery and memory card have been removed, close the battery door so it does not get damaged during disassembly.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
