Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Help
Bewerken van stap 8 —
Stap type:
Sleep om te herschikken
This isn't nearly as pretty as the front, but there's some things worth noting here.
There are four cables that connect the LCD to the iMac:
DisplayPort
Temperature sensor
LED backlight
LED backlight sync
The key thing to note is that there's no special shortcut from the LCD to the external Mini DisplayPort connector. The signal will need to go through the logic board, so you'll need to have your iMac powered on if you want to display from an external video source.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
