Ga door naar hoofdinhoud
Help
Bewerken van stap 5 —
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden de handleiding die deze stap bevat.
Stap type:
Sleep om te herschikken
Removing The Top Bezel
Make sure the console is standing up. Then look into the grill.
The red circles mark the location of tabs (like this on the other side too). Together there are 6. To pull off the top grill, use a small round object to insert into the holes onto the tab, then pull up on the grill, freeing it partially. You need to do this to all 6 tabs to ensure you don't break them. Then lift the grill up. This process is the same for the top and bottom.
The Tabs Are Circled In Yellow
As you can see, I got lazy and broke two of them. Try not to do the same, yet as long as most of the tabs are there, it should still go back on. So don't sweat it, if you break them.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
