Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Help
Bewerken van stap 19 —
Stap type:
Sleep om te herschikken
The Samsung Galaxy Watch earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
Display repair is prioritized.
No overlapping design of cables, no fragile ZIF connectors.
Despite the water-resistant construction, the opening procedure is straightforward and glueless (though it requires an uncommon tri-point driver).
The battery only uses mild adhesive, but the motherboard must be removed for access.
A lot of components are modular and can be replaced separately—except for the frequently-used twin button cables, which are soldered to the motherboard.
The glass digitizer and screen are fused together—meaning a full replacement will be quick and easy, but glass-only repairs will be impractical.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
