Ga door naar hoofdinhoud
Help
Bewerken van stap 6 —
Stap type:
Sleep om te herschikken
PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
Your monitor should look like this, with a small gap between the main board and the rear casing.
The next step will merely free the volume control dial from the casing and NOT free the main board from the casing.
To remove the main board from the casing, you MUST desolder the antenna cable and two battery contacts from the board.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
