Ga door naar hoofdinhoud
Huawei Mate 20 Pro Teardown
Engels
Nederlands
Stap 17 vertalen
Stap 17
Huawei Mate 20 Pro Teardown, Final Thoughts: stap 0, afbeelding 1 van 1
Final Thoughts
  • The Huawei Mate 20 Pro earns a 4 out of 10 on our repairability scale (10 is the easiest to repair):
  • Many components are modular and can be replaced independently.
  • Battery replacement requires removing only the back panel and midframe.
  • Only standard Phillips screws are used along with an average amount of adhesive.
  • Because of the sandwich build around the motherboard, there are more flex connectors than average and repairs will consume more time.
  • Glued-down front and back glass means greater risk of breakage while making repairs difficult to start.
  • Screen repairs require a lot of disassembly while battling tough adhesive.
  • A broken screen probably means you need to replace the fingerprint reader as well, or vice versa.
Vertaling hier toevoegen
