Inleiding
This guide will show you the steps to take the back off the ZTE T81 and remove the mainboard and the screen.
Wat je nodig hebt
Remove the back cover, SIM card, battery and SD card.
Remove the 9 screws under the back cover. The top left screw is covered by a white "warranty void" sticker.
Separate the frame from the mainboard
Pry apart the frame with the battery holder and camera housing from the mainboard of the phone.
Remove the digitizer cable and separate the digitizer/front glass from the rest of the phone.
Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on.
