Inleiding
A video step teardown of the ZTE Axon.
Wat je nodig hebt
8 opmerkingen
My camera stop working...Everytime I open it," Unable to connect to camera,Camera has been disabled because of security policies or is being used by other apps" I tried fully reseting the phone but it still won't work. Does anyone know how to fix it?
throw it in the garbage because this a garbage phone honestly. I did the same because Fido were not able and willing to fix it . It was less than a month old.
yes I've similar issues and while FIDO was happy to take my money to sell the phone, FIDO disowned it months later when it provided to be a total piece of crap and would not assist to have it repaired... FIDO ceased to carry this model less one hear after bringing it to market. totall suspect.
On the first day, SIM tray won't pop up. I know I placed a hand-cut nano-SIM as strictly prohibited. I sent it back to the manufacturer's repair center, before I mess up. The reply was just shocking, the repair costs more than I paid for the purchase! I may keep it as a Wi-Fi-only smart phone , or challenge to fix it by myself to damp as a garbage at worst.
Your video suggests to remove the card tray first. If it is mandated, I have no way to proceed. The stupid appreciates any suggestion to proceed. Thanks.
You don't really know how bad a phone this is until you disassemble it. This side trim (which also seals the display unit) comes apart when you start to pry the back off. The battery is glued into the body, and when you remove the battery, the foil wrap around it also comes apart. The foil is literally the battery case, so you have a dangerously exposed battery once you remove it. The battery ribbon cable is so thin that it broke apart from from minimal force of removing the battery. There is also a loose piece of copper in there, which may explain why the new battery won't charge (or, it's a defective replacement, which wouldn't surprise me, either). I also see why my 4G signal is so low--the antenna is a piece of foil on the inside of the top cap on the back. It makes a very light contact with connectors on the body of the phone. Horrible design. This phone is the worse piece of junk I have ever seen. I bought it for $150 because it had specs similar to the Samsung Galaxy. No comparison.
I have a ZTE axon 7 with a weakening battery. I have purchased a new battery but do not want to attempt installing it. My concern is to not lose any of my stuff . Where can I find a competent tech to do the job.
davfrmaine@gmail.com
Thanks for this video. My Axon Pro fell and dislodged the top backplate and this helped me understand how to fix the problem. The unit was purchased from Newegg.ca and had a 2 year replacement warranty. I had the camera fail about a year into it, and received a replacement by mail in just a few weeks. About 2 years less a moth my battery stopped charging and they again replaced the unit within day with an inferior model. After some back and forth I finally got the correct unit. So not too bad for a $250 dollar purchase in 2016. I fully expected this to last barely a year. Certainly the warranty team leave a lot to be desired in claiming they had no replacements but finally finding one. They also fail in that the OS is no longer supported and this could lead me to get hacked. I had Samsung before and I must admit this unit seems to be very competitive. Next will be a Pixel with the money I saved !
Come on now. Don't rely on videos to much, using my data a lot.
Nickoakz - Antwoord
Hello,
I want to fix my cracked screen by using this guide. Do I need to disassemble my whole phone like your videos to replace only the cracked screen?
Tom Vandesmal - Antwoord
I have the same question about replacing a cracked screen.
Brian Formato -
what do you use to slide open the edges?..
ley - Antwoord
